11-05-2019, 14:30 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: UK NETWORK SOURCE
Member: 908175 Status: Offline Thanks Meter: 314 | need help to unlock imo Q2 i have all pack [SOLVED=UNLOCKED] |
11-05-2019, 14:33 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Use SPDtool , diag mode and one of the generic models. Probably will work fine with imo q2 plus selected Br |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
11-05-2019, 14:42 | #4 (permalink) | |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Because you don't read what the soft says. Phone must be connected powered off to usb when the sw is looking for it ! And obviously you must have the spreadtrum drivers installed Br | |
11-05-2019, 14:42 | #5 (permalink) |
Member: 908175 Status: Offline Thanks Meter: 314 | which drivers do i need for it? Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable ERROR: SCI USB2Serial port not found ! BE sure the drivers from support were installed; |
11-05-2019, 14:44 | #6 (permalink) | |
Did you read my previous reply !? You have the drivers present on the spdtool archive in DRIVERS folder ! Br | |
11-05-2019, 14:51 | #7 (permalink) | |
Member: 908175 Status: Offline Thanks Meter: 314 | Quote:
i have downalod drivers but when conect the phone it dsont aske for them | |
11-05-2019, 14:54 | #8 (permalink) |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Is you who must install these drivers. So hard to hard to click one exe to install them !? As far as im concerned if the phone is off and is connected to usb while the sw is searching for it must be detected. Else drivers missing or you have an other model. Other option is to buy code\ https://www.furiousgold.com/en/remot...k-code-by-imei Br |
11-05-2019, 14:54 | #9 (permalink) |
Member: 908175 Status: Offline Thanks Meter: 314 | its done thatnks for help Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem26.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM40]; Entering diagnostic mode; Done; Chip type: 8860:B100 Platform Version: MOCORTM_14B_7731C_W16.12.2_Debug Project Version: sc7731C_CP0_modem BASE Version: TM_BASE_15B_W16.12.2 HW Version: sc7731C_CP0_modem 03-11-2016 21:00:19 Build number: IMO_Q2_TESCO-user 5.1 LMY47D eng.root.20170601.165602 release-keys PHONE INFO: BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 862413-02-228838-7 SW IMEI[1]: 300000-00-000000-0 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON BKP saved to : BKP_000000-00-000000-0_862413-02-228838-7_8860B100_5_11_2019_13_53_13.spd SIM_LOCK TYPE: 2 IMEI: 862413-02-228838-7 UNLOCK CODE: 69536547 Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_5_11_2019_13_54_11.txt Time needed - 00:01:02 |
