03-04-2015, 02:46 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Cuba-Holguin
Member: 256260 Status: Offline Thanks Meter: 726 | need help for unlock OT-1060 [SOLVED] For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (SCI USB2Serial) Preparing to sync; Port opened [COM401]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; ERROR: Sync failed; allways give this error i use winXP and Win 7 32 and imposible to connect BR Yaio... |
03-04-2015, 12:40 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Change port number from 401 to something lower , install the drivers that came with the soft and reset the pc after. You have the video bellow |
03-05-2015, 00:35 | #3 (permalink) |
Member: 256260 Status: Offline Thanks Meter: 726 | and test Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (SCI USB2Serial) Preparing to sync; Port opened [COM66]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; ERROR: Sync failed; and upsdate the driver and use another tool for spd Cpu and work perfect but imposible to flash this phone and test 2 phone OT-1060 and Amgoo AM83 and same result |
03-05-2015, 01:28 | #4 (permalink) |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | AMGO AM83 has 2 types of cpus. SPD6610 and SPD6531 . Probably you have SPD6610 model and in this case select ALCATEL OT-1051. For OT-1060 try selectimg ITEL 2080 as it might have an new cpu revision. Br |
03-25-2015, 21:40 | #9 (permalink) | |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Quote:
Drivers are inside the archive SPDTooL_v1.0.0.2000.rar . And in order this phone to be detected you must keep pressed boot key (boot key can be *, 0, call key etc), insert usb and then battery. All this whiel the sw is looking for the mobile Br | |
