05-14-2014, 02:09 | #1 (permalink) |
No Life Poster Join Date: Apr 2013 Location: PT
Member: 1919025 Status: Offline Sonork: 100.1657804 Thanks Meter: 417 | Need some hints Everytime I try to unlock a vodafone ZTE 945 it gives me error I connect the data usb cable to pc Wait until finish installing driver and have restarted the pc, but it only detects ZTE Handset USB Modem I choose the only option I have and even that it gives me error Here it is the Log Software engine version: 1.0.0.8933 Searching phone ... Error ... ! Log file saved to: LOG_14_05_2014_01_52_21.txt Time needed - 00:00:18 Can anyone please give some hints or please tell me what am I doing wrong? I am having some dificultys on this tool, althout it apears to be a quiete simple one it is proving to be the oposit for me :-D All 4 ZTE cables from Furious box dont serve on this equipment I am using it's usb data cable if that is the problem please recomend me a correct cable for equipments with this usb jack so that I can use them with this and other mobile phones. So I dont always have this same problem. Even if cable belongs to onother box I just need one compatible with FuriousGold Box so that I can order him |
05-14-2014, 10:33 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Diagnostic port must be used. And try connecting phone in FTM mode, Vol down+power. You can see here no pbs unlocking it http://forum.gsmhosting.com/vbb/f272...easly-1613585/ Br |
The Following 2 Users Say Thank You to .:hack3r2k:. For This Useful Post: |
05-19-2014, 01:16 | #4 (permalink) |
Member: 1919025 Status: Offline Sonork: 100.1657804 Thanks Meter: 417 | First Part Done At firs I have to say that the ZTE Pen Vodafone K3571-Z it's done now remainig the Phone that I will try also as soon as possible because I havent got it with me now But in the middle of the week will try to keep everyone posted about the result as promissed But first part is already done as stated on the folowing log Thanks .:hack3r2k:. Software engine version: 1.0.0.8933 Searching phone ... MODEL : VODAFONE K3571-Z COMPILED DATE : Apr 23 2010 16:31:00 RELEASE DATE : Mar 22 2010 13:00:00 FIRMWARE INFO : BD_P680A8W900V1.0.0B03 IMEI : 35959103330182-6 BLUETOOTH ADDR : 00 00 00 00 00 00 ENTERING SECURE MODE; ENTERED; GETTING CODE HASH (0); GETTING SIGN; GETTING LOCK; CALCULATING; UNLOCKED ! NOW RECONNECT MODEM TO USB PORT ! Log file saved to: LOG_19_05_2014_00_59_51.txt Time needed - 00:00:02 |
The Following User Says Thank You to Rui Romano For This Useful Post: |
05-22-2014, 00:09 | #5 (permalink) |
Member: 1919025 Status: Offline Sonork: 100.1657804 Thanks Meter: 417 | HAS PROMISSED IT WORKED AS LOG SHOWS Software engine version: 1.0.0.8938 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Nov 23 2010 01:09:00 RELEASE DATE : May 12 2010 18:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-53303002 IMEI : 86448500015111-6 BLUETOOTH ADDR : 26 EF 88 37 F5 98 TAG_ID:P727AB04 UNSUPPORTED FIRMWARE VERSION FOR UNLOCK.IF THE CODE(S) DONT WORK SELECT DUMP ME FROM JOBS AND SEND THE RESULTED FILE TO SUPPORT. FOR ACER AND BOSTON MODELS FLASH DEVICE WITH FIRMWARE FROM SUPPORT CALCULATING; UNLOCK CODE [OLD]: 81264123 UNLOCK CODE [NEW]: 31725411 COUNTER CLEAR DONE; UNLOCKED ! Log file saved to: LOG_22_05_2014_00_04_04.txt Time needed - 00:00:11 THANKS .:Hack3r2k:. |
