03-07-2013, 09:16 | #3 (permalink) |
Freak Poster Join Date: Sep 2006 Location: Mada
Member: 357827 Status: Offline Thanks Meter: 14 | Same with me too, i connect phone with serial but nothing happen!! pin are correct, her is version : Alcatel ot 217 KF2A0000 BF2A0000 UF2A0000 CF2ADS00 XF2ADS00 SF2A0042 TF26J000 JF2A0000 Plz look for this, Bro |
03-08-2013, 10:45 | #4 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Means you soldered the wires wrong. Switch rx with tx be sure gnd is soldered Br | |
06-11-2013, 23:41 | #5 (permalink) |
Registered User Join Date: Sep 2005 Location: On the path Age: 43
Member: 182574 Status: Offline Thanks Meter: 54 | unlock ot-217x same error COM opened ok; Phone must be poewered off; Keep presing the button ! (for USB connection keep space key pressed and insert the usb cable) COM opened ok; Phone must be poewered off; Keep presing the button ! (for USB connection keep space key pressed and insert the usb cable) COM opened ok; Phone must be poewered off; Keep presing the button ! (for USB connection keep space key pressed and insert the usb cable) COM opened ok; Phone must be poewered off; Keep presing the button ! (for USB connection keep space key pressed and insert the usb cable) COM opened ok; Phone must be poewered off; Keep presing the button ! (for USB connection keep space key pressed and insert the usb cable) COM opened ok; Phone must be poewered off; Keep presing the button ! (for USB connection keep space key pressed and insert the usb cable) COM opened ok; Phone must be poewered off; Keep presing the button ! (for USB connection keep space key pressed and insert the usb cable) COM opened ok; Phone must be poewered off; Keep presing the button ! (for USB connection keep space key pressed and insert the usb cable) i verified connection and reverse rx tx and the same problem phone not connect ot-217x -2ALPFR1 866050011663729 any solution and thx |
06-12-2013, 08:37 | #6 (permalink) | |
NCK: 1901487597 NSCK: 0765279565 SPCK: 2983287168 PCK: 0421402163 | |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
