Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 11-10-2011, 02:18   #1 (permalink)
Registered User
Member: 1040340
Thanks Meter: 58
Ot660 dead in flash
ALCATEL OT660 orange Ivory coast is not in simfree so i need to flash it.
I download flash in furious support OT660_ALEU_sw335.bin when i try to flash handset i get this:
Make your handset power off, plug in the UART cable!
Product: OT-660
Load DA file...
Load AUTH file...
Load flash image file...
Load flash image file failed!
Please double check whether you select the correct flash image file!
I try the same flash file from another friend now the phone dead after few time in download flash image file :
Product: OT-660
Load DA file...
Load AUTH file...
Start to connect the handset, keep pressing the power on key!
Start to flash handset image...
IMEI: 352387031373801
Provider ID: 660X-2DRGTE5
Security information version: N/A
Detect special firmware version!
If the handset is reflashed with SIMFree version, it may not power on correctly!
If so, you can try to repair the handset secure region with special golden file after flash process is done!
Downloading flash image now...
Flash handset image failed!
Error Code: 16812066
Please double check the cable and handset connection!
Try it again!
Help me to revive phone, i must buy another phone.
Old 11-10-2011, 08:49   #2 (permalink)
Member: 1326910
Thanks Meter: 240
Product: OT-660
Load DA file...
Load AUTH file...
Product: OT-660
Load DA file...
Load AUTH file...
Try it again!
Hi,
Try the flash file as below for your phone's same provider ID.
https://www.rapidshare.com/files/374...0X-2XRGTE5.zip
B.R.
Eason
Old 11-15-2011, 13:22   #3 (permalink)
Registered User
Member: 1040340
Thanks Meter: 58
Originally Posted by Eason_MildFire View Post
Hi,
B.R.
Eason
Product: OT-660
Load DA file...
Load AUTH file...
Error Code: 1930
Try it again!
Phone dead.
Old 11-16-2011, 03:15   #4 (permalink)
Member: 1326910
Thanks Meter: 240
Product: OT-660
Load DA file...
Load AUTH file...
Error Code: 1930
Try it again!
Phone dead.
Hi,
Please retry the download action.
And please make sure the handset has full battery.
Your error ID means the connection between PC and handset is interrupted.
Suggestion,
1. What's kind of cable do you use? UART cable or just solder on test pin?
Check the UART port on handset side if you use UART cable. Or check your solder if use test pin.
2. Make sure your handset has enough battery. If it has enough power, the download process should be always able to be launched.
3. Make sure you use the latest 1.0.2.0 latest Pack 8 exe version.
B.R.
Eason
Old 11-20-2011, 23:38   #5 (permalink)
Registered User
Member: 1040340
Thanks Meter: 58
Hi,
Suggestion,
B.R.
Eason
I try all you say bro but my handset dead.
Progress stop after few time.
The Following User Says Thank You to DIDIER2009 For This Useful Post:
Old 11-21-2011, 02:05   #6 (permalink)
Member: 1326910
Thanks Meter: 240
Hi,
What did you try? Please provide more detailed feedback.
Answer my below questions first.
I met similar problem like yours before. It becuase of the port on handset's side is "loose". Need to press the cable hard to keep the good connection. And if you use test pin, check your solder.
How much battery level did you see?
Again! Your error ID means the cable connection is broken. It is hardware or connection problem, pack8 is just SW application. You need to make sure you use it correctly and all relevant HW is good. You are not the only or first user for OT-660 such a old model.
B.R.
Eason
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
Lock 2 in nokia 51xx/61xx Pablo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-31-1999 04:35
Page generated in 0.23341 seconds with 9 queries
