08-22-2019, 08:55 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 992 | P20 Demo Remove not working SMALL TUTORIAL FOR VENDOR / COUNTRY CHANGE [DEMO REMOVE] ON HUAWEI P20 / P20 Pro i did all steps but phone not going to update mode Fly Captain Huawei Resurrector 0.0.0.34 user:0000000 Device detected: COM4: HUAWEI USB COM 1.0 (COM4) BOOTLOADER File to update: Kirin970_T2_A8.1_V5 OEM File to update: EML-L29 8/22/2019 9:44:58 AM Starting to write device... Process identifier:4619518 Writing bootloader... Writing Kirin970_T2_A8.1_V5_3.dtwork... Writing Kirin970_T2_A8.1_V5_4.dtwork... Writing Kirin970_T2_A8.1_V5_5.dtwork... Waiting for fastboot device... Device found: 0123456789ABCDEF Looking for a device in fastboot mode Device found: 0123456789ABCDEF Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... Build number: :EML-L29 8.1.0.107D(EUC652) Model: EML-L29 Battery state: 0 OEM lock state info: FB LockState: UNLOCKED USER LockState: LOCKED OEM get bootinfo: unlocked Writing OEMINFO partition OEMINFO partition UPDATE ...OK Software written 8/22/2019 9:46:10 AM Writing device finished OK |
08-22-2019, 08:57 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,552 | Now you must flash the customization. If is not going to update mode is because that when the phone is opened the vol up+down don't make contact to the board. you must put pressure in that area Br |
08-22-2019, 09:14 | #3 (permalink) |
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 992 | I also tried to flash board software but it failed and now phone is only fastboot not upgrade mode and not on normal. what is the ways i can make it alive again. |
08-22-2019, 09:16 | #4 (permalink) | |
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 992 | Quote:
Maybe is my mistake that i was busy doing board firmware . but now i just want to make it alive... | |
08-22-2019, 09:17 | #5 (permalink) | |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,552 | Quote:
Where exact in that freaking tutorial did you read you must write board sw ? Now you must boot phone over tp and write normal firmware + customisation Br | |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
08-22-2019, 11:13 | #6 (permalink) |
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 992 | Dear sir if i connect directly with tp it said no device found then i did update oem info and then phone goes into fastboot mode. and it gives me this error i used this file from support On screen phone shows with Grean writing PHONE Locked FRP Lock Emily-L29C 8.1.0.130D(EUC652)_Firmware_Android8.1.0_EMUI8.1.c fs Fly Captain Huawei Resurrector 0.0.0.35 user:00000000 Looking for a device in upgrade mode No devices detected in upgrade mode Device found: 0123456789ABCDEF Extracting recovery partition Extracting partition: ERECOVERY_KERNEL ERECOVERY_KERNEL partition extracted Extracting partition: ERECOVERY_RAMDISK ERECOVERY_RAMDISK partition extracted Extracting partition: ERECOVERY_VENDOR ERECOVERY_VENDOR partition extracted 8/22/2019 12:01:57 PM Starting to try Rescue Recovery... Looking for a device in fastboot mode Device found: 0123456789ABCDEF Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... Build number: :EML-L29 8.1.0.107D(EUC652) Model: EML-L29 Battery state: 0 OEM lock state info: FB LockState: UNLOCKED USER LockState: LOCKED OEM get bootinfo: unlocked Process identifier:4619819 Getting build number... Getting base version... Waiting for answer... Getting cust version... Getting preload version... Erasing ver .. . Writing rescue_recovery_kernel partition rescue_recovery_kernel partition UPDATE FAIL Fatal error: Cannot access to device Cannot enter in Recovey mode I got this error then i used this file and now i got this error Emily-L29C 8.1.0.107Da(EUC652)_Firmware_Android8.1.0_EMUI8.1. 0_05015AFL Looking for a device in upgrade mode No devices detected in upgrade mode Device found: 0123456789ABCDEF Detecting recovery partition File size: 4,968,725,288 bytes Current version(CURVER): Emily_Global_C652 ERECOVERY_KERNEL partition found ERECOVERY_RAMDISK partition found ERECOVERY_VENDOR partition found 8/22/2019 12:08:05 PM Starting to try Rescue Recovery... Looking for a device in fastboot mode Device found: 0123456789ABCDEF Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... Build number: :EML-L29 8.1.0.107D(EUC652) Model: EML-L29 Battery state: 0 OEM lock state info: FB LockState: UNLOCKED USER LockState: LOCKED OEM get bootinfo: unlocked Process identifier:4619850 Getting build number... Getting base version... Waiting for answer... Getting cust version... Getting preload version... Erasing ver .. . File size: 4,968,725,288 bytes Current version(CURVER): Emily_Global_C652 Writing rescue_recovery_kernel partition rescue_recovery_kernel partition UPDATE FAIL Fatal error: Cannot access to device Cannot enter in Recovey mode Please guide me if i m doing wrong things. or guide me how must i do step by step. Thanks for ur help. here is without Recuse Recovery USB Device INSERTION Type: @oem25.inf,%hwfastboot%;Android Sooner Single ADB Interface VidPid: VID_18D1&PID_D00D Instance id: 0123456789ABCDEF Looking for a device in upgrade mode No devices detected in upgrade mode Device found: 0123456789ABCDEF 8/22/2019 12:16:17 PM Starting to write device in FASTBOOT mode... File size: 4,968,725,288 bytes Current version(CURVER): Emily_Global_C652 Looking for a device in fastboot mode Device found: 0123456789ABCDEF Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... Build number: :EML-L29 8.1.0.107D(EUC652) Model: EML-L29 Battery state: 4888mv OEM lock state info: FB LockState: LOCKED USER LockState: LOCKED OEM get bootinfo: locked Device with unsupported security patch Process identifier:4619882 Erasing ver .. . Writing XLOADER partition XLOADER partition UPDATE :FAIL Command not allowed Device with unsupported security patch 8/22/2019 12:16:34 PM Writing device finished - INCOMPLETE |
08-22-2019, 11:14 | #7 (permalink) | |
Dont click use recovery Sent from my iPhone using Tapatalk Pro | |
08-22-2019, 14:45 | #8 (permalink) | |
without recovery it flashed sucessfully i used this file Emily-L29C 8.1.0.130D(EUC652)_Firmware_Android8.1.0_EMUI8.1.c fs Flashing complete but phone is still not going to update mode and if i plug in charger it show charging for a while then blank screen if i switch it on it showing log and then blank. maybe is not full firmware or i must flash it with another firmware . if i try this firmware from easyfirmware its not flashing Emily-L29C 8.1.0.107Da(EUC652)_Firmware_Android8.1.0_EMUI8.1. 0_05015AFL This phone show C652 can i convert it to C185 or C432 if possible Revision: 2 Fly Captain Huawei Resurrector 0.0.0.35 user:0000000 Looking for a device in upgrade mode No devices detected in upgrade mode Device found: 0123456789ABCDEF 8/22/2019 3:30:17 PM Starting to write device in FASTBOOT mode... Looking for a device in fastboot mode Device found: 0123456789ABCDEF Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... IMEI:867128030722145 IMEI1:867128030732151 MEID:A000008C368DFE Build number: :EML-L29 8.1.0.107D(EUC652) Model: EML-L29 Battery state: 0 OEM lock state info: FB LockState: UNLOCKED USER LockState: LOCKED OEM get bootinfo: unlocked Device with unsupported security patch Process identifier:4620463 Erasing ver .. . Extracting partition XLOADER... Writing XLOADER partition XLOADER partition UPDATE ...OK Extracting partition FW_LPM3... Writing FW_LPM3 partition FW_LPM3 partition UPDATE ...OK Extracting partition HHEE... Writing HHEE partition HHEE partition UPDATE ...OK Extracting partition FASTBOOT... Writing FASTBOOT partition FASTBOOT partition UPDATE ...OK Extracting partition VECTOR... Writing VECTOR partition VECTOR partition UPDATE ...OK Extracting partition VBMETA... Writing VBMETA partition VBMETA partition UPDATE ...OK Extracting partition MODEMNVM_UPDATE... Writing MODEMNVM_UPDATE partition MODEMNVM_UPDATE partition UPDATE ...OK Extracting partition MODEMNVM_CUST... Writing MODEMNVM_CUST partition MODEMNVM_CUST partition UPDATE ...OK Extracting partition TEEOS... Writing TEEOS partition TEEOS partition UPDATE ...OK Extracting partition TRUSTFIRMWARE... Writing TRUSTFIRMWARE partition TRUSTFIRMWARE partition UPDATE ...OK Extracting partition SENSORHUB... Writing SENSORHUB partition SENSORHUB partition UPDATE ...OK Extracting partition FW_HIFI... Writing FW_HIFI partition FW_HIFI partition UPDATE ...OK Extracting partition KERNEL... Writing KERNEL partition KERNEL partition UPDATE ...OK Extracting partition RAMDISK... Writing RAMDISK partition RAMDISK partition UPDATE ...OK Extracting partition RECOVERY_RAMDISK... Writing RECOVERY_RAMDISK partition RECOVERY_RAMDISK partition UPDATE ...OK Extracting partition RECOVERY_VENDOR... Writing RECOVERY_VENDOR partition RECOVERY_VENDOR partition UPDATE ...OK Extracting partition RECOVERY_VBMETA... Writing RECOVERY_VBMETA partition RECOVERY_VBMETA partition UPDATE ...OK Extracting partition ERECOVERY_KERNEL... Writing ERECOVERY_KERNEL partition ERECOVERY_KERNEL partition UPDATE ...OK Extracting partition ERECOVERY_RAMDISK... Writing ERECOVERY_RAMDISK partition ERECOVERY_RAMDISK partition UPDATE ...OK Extracting partition ERECOVERY_VENDOR... Writing ERECOVERY_VENDOR partition ERECOVERY_VENDOR partition UPDATE ...OK Extracting partition ERECOVERY_VBMETA... Writing ERECOVERY_VBMETA partition ERECOVERY_VBMETA partition UPDATE ...OK Extracting partition HDCP... Writing HDCP partition HDCP partition UPDATE ...OK Extracting partition DTS... Writing DTS partition DTS partition UPDATE ...OK Extracting partition DTO... Writing DTO partition DTO partition UPDATE ...OK Extracting partition CACHE... Erasing CACHE partition Partition CACHE erased Writing CACHE partition CACHE partition UPDATE ...OK Extracting partition SYSTEM... Writing SYSTEM partition sending sparse file 399414244 bytes Waiting for answer... send sparse file OK sending sparse file 458636928 bytes Waiting for answer... send sparse file OK sending sparse file 465397676 bytes Waiting for answer... send sparse file OK sending sparse file 466138932 bytes Waiting for answer... send sparse file OK sending sparse file 459040732 bytes Waiting for answer... send sparse file OK sending sparse file 396501148 bytes Waiting for answer... send sparse file OK sending sparse file 395298512 bytes Waiting for answer... send sparse file OK sending sparse file 471747876 bytes Waiting for answer... send sparse file OK sending sparse file 96267052 bytes Waiting for answer... send sparse file OK SYSTEM partition UPDATE ...OK Extracting partition CUST... Erasing CUST partition Partition CUST erased Writing CUST partition CUST partition UPDATE ...OK Extracting partition ISP_FIRMWARE... Writing ISP_FIRMWARE partition ISP_FIRMWARE partition UPDATE ...OK Extracting partition MODEM_FW... Writing MODEM_FW partition MODEM_FW partition UPDATE ...OK Extracting partition HISEE_IMG... Writing HISEE_IMG partition HISEE_IMG partition UPDATE ...OK Extracting partition HISEE_FS... Writing HISEE_FS partition HISEE_FS partition UPDATE ...OK Extracting partition VERSION... Writing VERSION partition VERSION partition UPDATE ...OK Extracting partition ODM... Writing ODM partition ODM partition UPDATE ...OK Extracting partition USERDATA... Erasing USERDATA partition Partition USERDATA erased Writing USERDATA partition USERDATA partition UPDATE ...OK Software written 8/22/2019 3:40:18 PM Writing device finished OK | |
08-22-2019, 14:47 | #9 (permalink) | |
Its not poasible. Wont accept any flash. Now put it in upgrade modr manually and reflash Sent from my iPhone using Tapatalk Pro | |
08-22-2019, 14:55 | #10 (permalink) | |
I dont know how can i put phone in Upgrade mode volume keys 100% ok.. and i also want to know that i see a file on same folder on support with this name update_EML-L29_hw_demo.cfs Should i download it or not. also i want to know why we cannot flash any firmware from other sites.. it only flashing this firmware from Furious gold support. | |
08-22-2019, 14:57 | #11 (permalink) | |
You have no freaking ideea what you do. Read the tutorial for p20 convert now and try to understand it and do what the hell it says in exact same order http://www.furiousgold.com/en/help/s...ei-p20-p20-pro Sent from my iPhone using Tapatalk Pro | |
08-22-2019, 15:54 | #12 (permalink) | |
I did exactly same and now here is log Looking for a device in upgrade mode No devices detected in upgrade mode Device found: 0123456789ABCDEF 8/22/2019 4:47:55 PM Starting to write device in FASTBOOT mode... Looking for a device in fastboot mode Device found: 0123456789ABCDEF Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... Build number: :EML-L29 8.1.0.107D(EUC652) Model: EML-L29 Battery state: 4567mv OEM lock state info: FB LockState: UNLOCKED USER LockState: LOCKED OEM get bootinfo: unlocked Device with unsupported security patch Process identifier:4620697 Erasing ver .. . Extracting partition CUST... Erasing CUST partition Partition CUST erased Writing CUST partition CUST partition UPDATE ...OK Extracting partition VERSION... Writing VERSION partition VERSION partition UPDATE ...OK Extracting partition USERDATA... Erasing USERDATA partition Partition USERDATA erased Writing USERDATA partition sending sparse file 469764848 bytes Waiting for answer... Waiting for answer... send sparse file OK sending sparse file 469764788 bytes Waiting for answer... Waiting for answer... send sparse file OK sending sparse file 224396600 bytes Waiting for answer... Waiting for answer... send sparse file OK USERDATA partition UPDATE ...OK Software written 8/22/2019 4:50:47 PM Writing device finished OK But problem is that phone is not going to upgrade mode. Basicaly my problem is not demo remove my problem is that phone is software is currupted . I still cannot go into upgrade mode. Now i used this file update_EML-L29_8.1.0.109(SP5C900)_hw_normal.cfs | |
08-23-2019, 08:44 | #15 (permalink) | |
Let me start from the begining . Phone was 100% ok . I tried to write Board Firmware becasue i was planing to repair imei . It started writing board firmware then give me error on 4% And now phone is not coming on. I will upload a pic in origional condition before i started experement Now i want my phone to bring back to life. i did change vendor and country values to hw and normal but still not flashing any firmware from easyfirmware or any stock firmware . Only flashing two firmwares from Furious Gold . But with then phones is not coming on completely. | |
The Following User Says Thank You to alamgarh For This Useful Post: |
