Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 08-22-2019, 08:55   #1 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 994
P20 Demo Remove not working
By folowing this
SMALL TUTORIAL FOR VENDOR / COUNTRY CHANGE [DEMO REMOVE] ON HUAWEI P20 / P20 Pro
i did all steps but phone not going to update mode
Fly Captain Huawei Resurrector 0.0.0.34
user:0000000
Device detected:
COM4: HUAWEI USB COM 1.0 (COM4)
BOOTLOADER File to update: Kirin970_T2_A8.1_V5
OEM File to update: EML-L29
8/22/2019 9:44:58 AM Starting to write device...
Process identifier:4619518
Writing bootloader...
Writing Kirin970_T2_A8.1_V5_3.dtwork...
Writing Kirin970_T2_A8.1_V5_4.dtwork...
Writing Kirin970_T2_A8.1_V5_5.dtwork...
Waiting for fastboot device...
Device found: 0123456789ABCDEF
Looking for a device in fastboot mode
Getting IMEI...
Getting build number...
Getting model ...
Getting battery state...
Getting backdoor info...
Getting lock state info...
Getting lock boot info...
Build number: :EML-L29 8.1.0.107D(EUC652)
Model: EML-L29
Battery state: 0
OEM lock state info:
FB LockState: UNLOCKED
USER LockState: LOCKED
OEM get bootinfo:
unlocked
Writing OEMINFO partition
OEMINFO partition UPDATE ...OK
Software written
8/22/2019 9:46:10 AM Writing device finished OK
Old 08-22-2019, 08:57   #2 (permalink)
.:hack3r2k:.'s Avatar
Member: 15022
Sonork: 100.53452
Thanks Meter: 61,564
Now you must flash the customization. If is not going to update mode is because that when the phone is opened the vol up+down don't make contact to the board. you must put pressure in that area
Old 08-22-2019, 09:14   #3 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 994
I also tried to flash board software but it failed and now phone is only fastboot not upgrade mode and not on normal. what is the ways i can make it alive again.
Old 08-22-2019, 09:16   #4 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 994
Thanks sir for ur kindness. i checked volume keys are working. but i think because i was trying to flash board firmware thats why now phone is not going to upgrade mode and not even getting on.
Maybe is my mistake that i was busy doing board firmware . but now i just want to make it alive...
Old 08-22-2019, 09:17   #5 (permalink)
Member: 15022
Sonork: 100.53452
Where exact in that freaking tutorial did you read you must write board sw ? Now you must boot phone over tp and write normal firmware + customisation
The Following User Says Thank You to .:hack3r2k:. For This Useful Post:
Old 08-22-2019, 11:13   #6 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 994
Dear sir if i connect directly with tp it said no device found
then i did update oem info and then phone goes into fastboot mode.
and it gives me this error
i used this file from support
On screen phone shows with Grean writing
PHONE Locked
FRP Lock
Emily-L29C 8.1.0.130D(EUC652)_Firmware_Android8.1.0_EMUI8.1.c fs
Fly Captain Huawei Resurrector 0.0.0.35
user:00000000
Looking for a device in upgrade mode
No devices detected in upgrade mode
Extracting recovery partition
Extracting partition: ERECOVERY_KERNEL
ERECOVERY_KERNEL partition extracted
Extracting partition: ERECOVERY_RAMDISK
ERECOVERY_RAMDISK partition extracted
Extracting partition: ERECOVERY_VENDOR
ERECOVERY_VENDOR partition extracted
8/22/2019 12:01:57 PM Starting to try Rescue Recovery...
Getting IMEI...
Getting model ...
Model: EML-L29
Battery state: 0
OEM get bootinfo:
unlocked
Process identifier:4619819
Getting base version...
Waiting for answer...
Getting cust version...
Getting preload version...
Erasing ver .. .
Writing rescue_recovery_kernel partition
rescue_recovery_kernel partition UPDATE FAIL
Fatal error: Cannot access to device
Cannot enter in Recovey mode
I got this error
then i used this file and now i got this error
Emily-L29C 8.1.0.107Da(EUC652)_Firmware_Android8.1.0_EMUI8.1. 0_05015AFL
Detecting recovery partition
File size: 4,968,725,288 bytes
Current version(CURVER): Emily_Global_C652
ERECOVERY_KERNEL partition found
ERECOVERY_RAMDISK partition found
ERECOVERY_VENDOR partition found
8/22/2019 12:08:05 PM Starting to try Rescue Recovery...
Getting IMEI...
Getting model ...
Model: EML-L29
Battery state: 0
OEM get bootinfo:
unlocked
Process identifier:4619850
Erasing ver .. .
Please guide me if i m doing wrong things. or guide me how must i do step by step.
Thanks for ur help.
here is without Recuse Recovery
USB Device INSERTION
Type: @oem25.inf,%hwfastboot%;Android Sooner Single ADB Interface
VidPid: VID_18D1&PID_D00D
Instance id: 0123456789ABCDEF
8/22/2019 12:16:17 PM Starting to write device in FASTBOOT mode...
Getting IMEI...
Getting model ...
Model: EML-L29
Battery state: 4888mv
FB LockState: LOCKED
OEM get bootinfo:
locked
Device with unsupported security patch
Process identifier:4619882
Erasing ver .. .
Writing XLOADER partition
XLOADER partition UPDATE :FAIL Command not allowed
8/22/2019 12:16:34 PM Writing device finished - INCOMPLETE
Old 08-22-2019, 11:14   #7 (permalink)
Member: 15022
Sonork: 100.53452
user:00000000
Getting IMEI...
Getting model ...
Model: EML-L29
Battery state: 0
OEM get bootinfo:
unlocked
Erasing ver .. .
I got this error
Getting IMEI...
Getting model ...
Model: EML-L29
Battery state: 0
OEM get bootinfo:
unlocked
Erasing ver .. .
Thanks for ur help.
Dont click use recovery
Sent from my iPhone using Tapatalk Pro
Old 08-22-2019, 14:45   #8 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 994
Thanks Dear sir.
without recovery it flashed sucessfully
i used this file
Flashing complete but phone is still not going to update mode and if i plug in charger it show charging for a while then blank screen if i switch it on it showing log and then blank.
maybe is not full firmware or i must flash it with another firmware .
if i try this firmware from easyfirmware its not flashing
This phone show C652 can i convert it to C185 or C432 if possible
Revision: 2
user:0000000
8/22/2019 3:30:17 PM Starting to write device in FASTBOOT mode...
Getting IMEI...
Getting model ...
IMEI:867128030722145
IMEI1:867128030732151
MEID:A000008C368DFE
Model: EML-L29
Battery state: 0
OEM get bootinfo:
unlocked
Process identifier:4620463
Erasing ver .. .
Extracting partition XLOADER...
XLOADER partition UPDATE ...OK
Extracting partition FW_LPM3...
Writing FW_LPM3 partition
FW_LPM3 partition UPDATE ...OK
Extracting partition HHEE...
Writing HHEE partition
HHEE partition UPDATE ...OK
Extracting partition FASTBOOT...
Writing FASTBOOT partition
FASTBOOT partition UPDATE ...OK
Extracting partition VECTOR...
Writing VECTOR partition
VECTOR partition UPDATE ...OK
Extracting partition VBMETA...
Writing VBMETA partition
VBMETA partition UPDATE ...OK
Extracting partition MODEMNVM_UPDATE...
Writing MODEMNVM_UPDATE partition
MODEMNVM_UPDATE partition UPDATE ...OK
Extracting partition MODEMNVM_CUST...
Writing MODEMNVM_CUST partition
MODEMNVM_CUST partition UPDATE ...OK
Extracting partition TEEOS...
Writing TEEOS partition
TEEOS partition UPDATE ...OK
Extracting partition TRUSTFIRMWARE...
Writing TRUSTFIRMWARE partition
TRUSTFIRMWARE partition UPDATE ...OK
Extracting partition SENSORHUB...
Writing SENSORHUB partition
SENSORHUB partition UPDATE ...OK
Extracting partition FW_HIFI...
Writing FW_HIFI partition
FW_HIFI partition UPDATE ...OK
Extracting partition KERNEL...
Writing KERNEL partition
KERNEL partition UPDATE ...OK
Extracting partition RAMDISK...
Writing RAMDISK partition
RAMDISK partition UPDATE ...OK
Extracting partition RECOVERY_RAMDISK...
Writing RECOVERY_RAMDISK partition
RECOVERY_RAMDISK partition UPDATE ...OK
Extracting partition RECOVERY_VENDOR...
Writing RECOVERY_VENDOR partition
RECOVERY_VENDOR partition UPDATE ...OK
Extracting partition RECOVERY_VBMETA...
Writing RECOVERY_VBMETA partition
RECOVERY_VBMETA partition UPDATE ...OK
Extracting partition ERECOVERY_KERNEL...
Writing ERECOVERY_KERNEL partition
ERECOVERY_KERNEL partition UPDATE ...OK
Extracting partition ERECOVERY_RAMDISK...
Writing ERECOVERY_RAMDISK partition
ERECOVERY_RAMDISK partition UPDATE ...OK
Extracting partition ERECOVERY_VENDOR...
Writing ERECOVERY_VENDOR partition
ERECOVERY_VENDOR partition UPDATE ...OK
Extracting partition ERECOVERY_VBMETA...
Writing ERECOVERY_VBMETA partition
ERECOVERY_VBMETA partition UPDATE ...OK
Extracting partition HDCP...
Writing HDCP partition
HDCP partition UPDATE ...OK
Extracting partition DTS...
Writing DTS partition
DTS partition UPDATE ...OK
Extracting partition DTO...
Writing DTO partition
DTO partition UPDATE ...OK
Extracting partition CACHE...
Erasing CACHE partition
Partition CACHE erased
Writing CACHE partition
CACHE partition UPDATE ...OK
Extracting partition SYSTEM...
Writing SYSTEM partition
sending sparse file 399414244 bytes
send sparse file OK
sending sparse file 458636928 bytes
send sparse file OK
sending sparse file 465397676 bytes
send sparse file OK
sending sparse file 466138932 bytes
send sparse file OK
sending sparse file 459040732 bytes
send sparse file OK
sending sparse file 396501148 bytes
send sparse file OK
sending sparse file 395298512 bytes
send sparse file OK
sending sparse file 471747876 bytes
send sparse file OK
sending sparse file 96267052 bytes
send sparse file OK
SYSTEM partition UPDATE ...OK
Extracting partition CUST...
Erasing CUST partition
Partition CUST erased
Writing CUST partition
Extracting partition ISP_FIRMWARE...
Writing ISP_FIRMWARE partition
ISP_FIRMWARE partition UPDATE ...OK
Extracting partition MODEM_FW...
Writing MODEM_FW partition
MODEM_FW partition UPDATE ...OK
Extracting partition HISEE_IMG...
Writing HISEE_IMG partition
HISEE_IMG partition UPDATE ...OK
Extracting partition HISEE_FS...
Writing HISEE_FS partition
HISEE_FS partition UPDATE ...OK
Extracting partition VERSION...
Writing VERSION partition
VERSION partition UPDATE ...OK
Extracting partition ODM...
Writing ODM partition
ODM partition UPDATE ...OK
Extracting partition USERDATA...
Erasing USERDATA partition
Partition USERDATA erased
Writing USERDATA partition
USERDATA partition UPDATE ...OK
Software written
8/22/2019 3:40:18 PM Writing device finished OK
Old 08-22-2019, 14:47   #9 (permalink)
Member: 15022
Sonork: 100.53452
Thanks Dear sir.
i used this file
This phone show C652 can i convert it to C185 or C432 if possible.
Its not poasible. Wont accept any flash. Now put it in upgrade modr manually and reflash
Old 08-22-2019, 14:55   #10 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 994
Thanks sir but Phones not going to Upgrade mode if i try to put it in upgrade mode a red light blink on top of screen
I dont know how can i put phone in Upgrade mode volume keys 100% ok..
and i also want to know that i see a file on same folder on support with this name
update_EML-L29_hw_demo.cfs
Should i download it or not.
also i want to know why we cannot flash any firmware from other sites..
it only flashing this firmware from Furious gold support.
Old 08-22-2019, 14:57   #11 (permalink)
Member: 15022
Sonork: 100.53452
You have no freaking ideea what you do. Read the tutorial for p20 convert now and try to understand it and do what the hell it says in exact same order
http://www.furiousgold.com/en/help/s...ei-p20-p20-pro
Old 08-22-2019, 15:54   #12 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 994
i really appriciate ur response
I did exactly same and now here is log
8/22/2019 4:47:55 PM Starting to write device in FASTBOOT mode...
Getting IMEI...
Getting model ...
Model: EML-L29
Battery state: 4567mv
OEM get bootinfo:
unlocked
Process identifier:4620697
Erasing ver .. .
sending sparse file 469764848 bytes
send sparse file OK
sending sparse file 469764788 bytes
send sparse file OK
sending sparse file 224396600 bytes
send sparse file OK
Software written
8/22/2019 4:50:47 PM Writing device finished OK
But problem is that phone is not going to upgrade mode. Basicaly my problem is not demo remove my problem is that phone is software is currupted .
I still cannot go into upgrade mode.
Now i used this file
update_EML-L29_8.1.0.109(SP5C900)_hw_normal.cfs
Old 08-22-2019, 16:23   #13 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 994
is it possible that you can help me via team viewer i can give you hold on my pc.
Old 08-23-2019, 07:59   #14 (permalink)
Member: 15022
Sonork: 100.53452
ANd you chnaged vendor and country values to hw and normal ? ALso what means the software is corrupted !?
Old 08-23-2019, 08:44   #15 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 994
Thanks for helping me.
Let me start from the begining .
Phone was 100% ok .
I tried to write Board Firmware becasue i was planing to repair imei .
It started writing board firmware then give me error on 4%
And now phone is not coming on.
I will upload a pic in origional condition before i started experement
Now i want my phone to bring back to life.
i did change vendor and country values to hw and normal but still not flashing any firmware from easyfirmware or any stock firmware .
Only flashing two firmwares from Furious Gold . But with then phones is not coming on completely.
File Type: jpg a5b4696a-73e3-4315-a4e3-655cf1787385.jpg (67.9 KB, 53 views)
The Following User Says Thank You to alamgarh For This Useful Post:
Page generated in 0.40341 seconds with 9 queries
