10-28-2016, 23:54 | #1 (permalink) |
No Life Poster Join Date: Sep 2005
Member: 185255 Status: Offline Thanks Meter: 42 | please add viettel v6502 For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem124.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM17]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6531 FdlStat: 0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00C2:0025:0037 - SIZE : 00800000 Reading phone info; PHONE INFO: NONE BT ADDR: 7B:C1:F1:34:05:2F SW IMEI[0]: 354085-06-652450-8 SW IMEI[1]: 354085-06-652451-6 SW IMEI[2]: 000000-00-000000-0 SW IMEI[3]: 000000-00-000000-0 SIMLOCK FLAG: ON FIXED NV BASE: 30780000 Reading NV; NV saved to : NV_000000-00-000000-0_354085-06-652450-8_65310001_28_10_2016_23_45_07.spd IMEI: 354085-06-652450-8 UNLOCK CODE: NONE Re-programming; NV programmed; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_28_10_2016_23_45_27.txt Time needed - 00:00:28 spd unlocked but still locked TinyUpload.com - best file hosting solution, with no limits, totaly free |
11-01-2016, 14:07 | #4 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Here is the patched file. Have fun: https://forum.gsmhosting.com/vbb/****************************/?89tt89na8bpt9n5 Br |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
04-16-2018, 13:15 | #5 (permalink) | |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | Quote:
04-16-2018, 22:08 | #6 (permalink) | |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Upload the backup and give em the link. ANd is normal the flash to be smaller since is compressed Br | |
04-17-2018, 14:12 | #8 (permalink) |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | |
04-19-2018, 05:25 | #11 (permalink) |
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | please check ur patch file ................I check 3 time flash write ok but set goes dead then I write backup and set power on .....give me ok file for unlock this phone I have almost 60 pieces |
04-19-2018, 17:22 | #12 (permalink) | |
I think you can read , no ? Do what i ask ! http://forum.gsmhosting.com/vbb/13085484-post10.html br;l) | |
