06-09-2018, 01:30 | #1 (permalink) |
Freak Poster Join Date: Feb 2007 Location: mexico Leon
Member: 455667 Status: Offline Thanks Meter: 47 | please help azumi L2z Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem76.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM5]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; |
06-09-2018, 08:00 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | 1. must remove usb and batt 2. insert usb 3. wait the soft to start searching the phone 4./ keep pressed boot key 5. insert batt must do it exactly as this. Also after drivers install pc must be rebooted and be sure you install the drivers that come inside the software archive Br |
06-09-2018, 22:04 | #3 (permalink) |
Member: 455667 Status: Offline Thanks Meter: 47 | still error!! if i do all like you put there,,,stuck in this step Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem76.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM5]; ERROR: Sync failed; if i do the next steps,, 1.-connect button in program 2.- connect the phone without battery with boot key pressed 3.- put the battery inside stuck in this step Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem76.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM5]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; ERROR: Sync failed; maybe this phone have some different hardware!!! |
06-11-2018, 09:08 | #4 (permalink) | |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
From what i see you have started some pc sync app start that opens the port (ex huwei hisuite, nokia, se suite etc) Br;() | |
06-12-2018, 20:05 | #5 (permalink) |
Member: 455667 Status: Offline Thanks Meter: 47 | look mr hacker!! hello mr hacker,,look the picture,,phone on the left can i do any process and all ok,,phone on the right is the phone of the errors,,,both are from telcel mexico,,both appear L2z model in the label,,but i think that inside is some different hardware,,,maybe different procesor!!! p.d. if can you helpme with a solution i really appreciate your help!! |
07-05-2018, 07:57 | #10 (permalink) |
Insane Poster Join Date: Apr 2016 Location: india
Member: 2562692 Status: Offline Sonork: 100.1679408 Thanks Meter: 51 | Azumi:l2z need h.can you help me unlock support AZUMI:L2Z NEED HELP CAN YOU HELP ME UNLOCK SUPPORT BECOUSE SIM CART NOT SUPPORT HAVE ANY SOLUTION GIVE ME PLEASE..... |
07-09-2018, 10:54 | #11 (permalink) |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Read flash using AZUMI L2Z NEW from the latest SPDTool version and attach the file here Br Last edited by .:hack3r2k:.; 07-09-2018 at 12:08. |
