11-13-2017, 12:52 | #1 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2231432 Status: Offline Thanks Meter: 4 | Please help, DORO 6520 unlocked success but still lock got 2, one tried many times now lost all attempt. the other still have 4 attempts Searching phone; Phone detected (@oem130.inf,%vcom_bootrom%;MediaTek USB Port) Preparing to start meta mode; COM opened ok; Phone must be powered off; Keep pressing the power button if serial used ! (for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable) Connecting; Meta mode entered; Baseband Chip: MT6276 Sw version: 6520_NF05_S17B_V03_M170531_MP Hw Version: SAGETEL76_1G512_11B_HW Reading phone info; IMEI: 356990-07-473347-0 Reading simlock info; Unlock codes: Locked to: 505-02 code_cat_n: 11112222 enabled: yes tries: 4 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:00:13 Log file saved to: LOG_13_11_2017_22_44_27.txt Searching phone; Phone detected (@oem130.inf,%vcom_bootrom%;MediaTek USB Port) Preparing to start meta mode; COM opened ok; Phone must be powered off; Keep pressing the power button if serial used ! (for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable) Connecting; Meta mode entered; Baseband Chip: MT6276 Sw version: 6520_NF05_S17B_V03_M170531_MP Hw Version: SAGETEL76_1G512_11B_HW Reading phone info; IMEI: 356990-07-430151-8 Reading simlock info; Unlock codes: Locked to: 505-02 code_cat_n: 11112222 enabled: no tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:00:21 Log file saved to: LOG_13_11_2017_22_51_40.txt |
11-15-2017, 10:48 | #5 (permalink) |
Member: 2231432 Status: Offline Thanks Meter: 4 | doro nvram for some reason dont know why cant attach to this thread reply. please try from this link: TinyUpload.com - best file hosting solution, with no limits, totaly free br, gsmbotol Last edited by .:hack3r2k:.; 11-16-2017 at 10:10. |
11-23-2017, 04:01 | #8 (permalink) |
Member: 2231432 Status: Offline Thanks Meter: 4 | well i that strange.... i was using brand new simcard, so for sure not a simcode issue. also tried on 2 phone. and second phone was still asking lock code. i will tried it again when when i got new one. thank for the support. br, gsmbotol |
01-09-2019, 20:25 | #9 (permalink) |
No Life Poster Join Date: Jun 2015 Location: the planet earth
Member: 2406539 Status: Offline Thanks Meter: 101 | doro 6520 was asking for unlock code, phone is unlocked but phone showing SOS calls only, invalid sim card, where as same sim card is working in another phone, tried with different sim cards as well but same error.. can you please check what's wrong..? Searching phone; Phone detected (@oem23.inf,%mtk6218%;MTK USB Port) Preparing to start meta mode; COM opened ok; Phone must be powered off; Keep pressing the power button if serial used ! (for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable) Connecting; Meta mode entered; Baseband Chip: MT6276 Sw version: 6520_NF05_S05B_V05_M170419_MP Hw Version: SAGETEL76_1G512_11B_HW Reading phone info; IMEI: 356990-07-4*****-* Reading simlock info; Unlock codes: Locked to: 460-01 code_cat_n: 11112222 enabled: no tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:00:21 Log file saved to: LOG_9_01_2019_19_21_23.txt Last edited by TMAC1122; 01-09-2019 at 20:31. |
