06-06-2014, 21:35 | #1 (permalink) |
Registered User Join Date: Oct 2005 Location: newzeland Age: 44
Member: 191225 Status: Offline Thanks Meter: 2,097 | pls help alcatel one touch 5020A-2BVDAU1 code error Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM307); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6575 Sw version: MAUI.11AMD.W1222SP.V15.F5.P31 Hw Version: JRDSH75_CU_JB_HW Reading phone info; IMEI: 013511-00-811079-4 Reading simlock info; NOTE: Most of the times one of the first variants will work ! MODEL: OT-5020 UNLOCK CODE: 2 9 7 2 5 7 4 8 MODEL: OT-5020 UNLOCK CODE: 2 8 5 2 1 8 8 6 MODEL: OT-5020 UNLOCK CODE: 2 5 3 7 1 5 3 8 MODEL: OT-5020 UNLOCK CODE: 2 7 5 3 1 3 9 0 Time needed - 00:00:29 ----------------------------- 5020A-2BVDAU1 ------------------ |
06-10-2014, 09:21 | #3 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,571 | Quote:
Reflash phone using OTSmart and read codes after again and will work Br;0 | |
07-07-2014, 03:58 | #4 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Darwin Northern Teretory Age: 40
Member: 136173 Status: Offline Sonork: 108426:ind Thanks Meter: 97 | unlock done no need to flash VCOM Port) TRYING TO OPEN COM98; DEVICE INFO: BB CHIP: MT6575_S01 [CB00, E201, 6575, FF] HW_STORAGE_EMMC: 0x484A0190 0x64314734 0xA3008604 0x8BA0B0D7 [SIZE=0xE7600000] IMEI1 [OTP 0001]: 013********811217-0 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5020A-2BVDAU1 USRDATA INFO: 0x4AF4C000 SIZE: 0x9C6B4000 Searching data; Locked to: 505-03 code_cat_n: 05785767 enabled: yes tries: 99 code_cat_ns: 17469286 enabled: no tries: 10 code_cat_sp: 00848300 enabled: no tries: 10 code_cat_c: 33469537 enabled: no tries: 10 code_cat_sim: 03418612 enabled: no tries: 10 code_cat_ns_sp: 19503074 enabled: no tries: 5 code_cat_sim_c: 06992906 enabled: no tries: 5 Code reading finished; Remove battery and cable; Time needed - 00:00:07 please note: no need to flash it , just connect in ot smart tool, select model 5020 and remove sim lock, it will generate more codes then mtk reader, input codes manually and you r done. |
The Following User Says Thank You to zipzap_kill For This Useful Post: |
07-26-2014, 07:26 | #5 (permalink) |
Freak Poster Join Date: May 2010
Member: 1302063 Status: Offline Thanks Meter: 4 | Hey Guys, I've tried the unlock code on this ot-5020A, none of them works. Then tried the OTsmart Tool, Shows the error message below. Can someone help PLZ? Searching phone; Phone detected (@oem281.inf,%vcom_preloader%;PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Gadget Serial (COM108); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6575 Sw version: MAUI.11AMD.W1222SP.V15.F5.P31 Hw Version: JRDSH75_CU_JB_HW Reading phone info; IMEI: 013511-00-81XXXXX Reading simlock info; NOTE: Most of the times one of the first variants will work ! MODEL: OT-5020 UNLOCK CODE: 3 8 7 0 8 9 5 0 MODEL: OT-5020 UNLOCK CODE: 4 2 5 4 3 5 0 7 MODEL: OT-5020 UNLOCK CODE: 3 2 3 2 5 7 4 1 MODEL: OT-5020 UNLOCK CODE: 4 0 8 6 1 2 8 3 This Message from OTsmart Tool Using library Brom_DLL_v7.1347.5 Searching phone; Phone detected (@oem281.inf,%vcom_preloader%;PreLoader USB VCOM (Android)) Preparing to start flash mode; ERROR: Device not found ! ERROR: BOOT_PHONE; |
07-26-2014, 14:46 | #6 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: Australia
Member: 177568 Status: Offline Thanks Meter: 147 | For OT-5020A, you have to use OTsmart. Try this: 1. Open OTsmart 2. Select model One Touch Mpop 3. Tick remove simlock 4. Press ' do job' then immediately connect phone ( without battery ) to computer via micro USB. It should work. Quote:
07-27-2014, 03:32 | #7 (permalink) | |
Member: 1302063 Status: Offline Thanks Meter: 4 | Quote:
I did exactly as what you written but shows **** Using library Brom_DLL_v7.1347.5 Searching phone; Phone detected (@oem281.inf,%vcom_preloader%;PreLoader USB VCOM (Android)) Preparing to start flash mode; ERROR: Device not found ! ERROR: BOOT_PHONE; Should I plug the Micro usb cable while the phone is off or on? When I do it when phone is off then shows the error above. If it's on then phone can't be detected. Anyone got any idea? | |
07-28-2014, 07:39 | #8 (permalink) | |
Member: 177568 Status: Offline Thanks Meter: 147 | when sw searching for phone, plug micro usb while phone is off and without battery. Quote:
