11-04-2013, 18:06 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: iraq
Member: 1215266 Status: Offline Thanks Meter: 129 | PLZ help Dead ALCATEL 2005X [SOLVED] Using library Brom_DLL_v5.1224.0 EMI Settings Loaded; Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (MTK USB Port) Preparing to start flash mode; ERROR: Comport open failed ! ERROR: BOOT_PHONE; |
11-05-2013, 09:48 | #2 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Quote:
Because you don't read as most of the people. You clicked blindly YES without reading yes means total phone format. So of course phone don't start anymore. Use Serial cable GW300 and flash Br | |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
11-05-2013, 20:26 | #4 (permalink) |
Member: 1215266 Status: Offline Thanks Meter: 129 | Mr. Daniel thanked EMI Settings Loaded; Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (MTK USB Port) Preparing to start flash mode; Requesting authorization; Done; Connecting; Downloading DA; Initializing; Requesting baudrate change; Done; DEVICE INFO: BB CHIP: MT6250_S0001 [CA01, 01, 625A, 05] MEMORY: [GigaDevice] GD25Q16 [2C:CB] [SIZE=0x01000000] IMEI1 [OTP]: 869795-01-246368-8 IMEI2 [OTP]: N/A Loading the file ... Cfg done ... File contents to write: [70008000-7000B7EB] ARM_BL [FFFFFFFF-00000406] ROOT_CERT [10008000-1001220F] ARM_EXT_BL [10CFE000-10CFE9AB] SECURE_RO_ME [10040000-102BE7D3] PRIMARY_MAUI [102F0000-1065D743] CUSTOM_PACK [10740000-10742E8B] STUDYPARA_ROM [10743000-10743517] JUMP_TABLE [10744000-10CE7BDF] VIVA Downloading bootloader... Done; Downloading images... Done; Done; Done; Done; Done; Done; Done; Formatting file system now... Done; Time needed - 00:01:38 |
12-03-2013, 14:24 | #5 (permalink) |
Freak Poster Join Date: Jul 2003 Age: 45
Member: 34261 Status: Offline Thanks Meter: 6 | After remove sim lock ... my phone is power on and off auto , After this i flashed wich correct firmware from support area and my phone live again but sim network lock - remove sim lock again and voala . Phone is unlocked and working normaly Thanks Furious |
