09-07-2017, 01:03 | #1 (permalink) |
Freak Poster Join Date: Jul 2009 Location: In The World
Member: 1068286 Status: Offline Thanks Meter: 182 | Problem with Alcatel onetouch 6045O Cricket i have Alcatel onetouch 6045O Cricket need unlock i try to Root phone using IDOL3_6045_ROOT.zip from the support but i get this error any solution please --- Waiting for device If you have been stuck in here: be sure you have the proper drivers installed and you truned the usb debbuging mode --- device connected the device will reboot to fastboot mode --- Waiting for device ************************************************** ********************* If you have been stuck in "waiting for device" for more than 1 minute then you should install the drivers now ************************************************** ********************* < waiting for device > downloading 'boot.img'... OKAY booting... FAILED (remote: unknown command) ************************************************** ********************* --- The phone will automatically restart two times --- ROOT complete after the restart ************************************************** ********************* Press any key to exit the program ... Thanks in advance |
09-08-2017, 10:20 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Just dial ###2324# and the diagnostic port will show up and you can unlock after Br; |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
09-08-2017, 11:14 | #4 (permalink) |
Member: 1068286 Status: Offline Thanks Meter: 182 | Connecting; Check your phone and “Always allow from this computer” and select ‘OK’. BRAND: TCL MODEL: 6045O ANDROID: v6.0.1 CPU: QCOM IMEI: Trying to get root access; ERROR: Be sure the phone is rooted or that you allowed root mode from the phone screen; Connecting; Check your phone and "Always allow from this computer" and select "OK". Connected; BRAND: TCL MODEL: 6045O ANDROID: v6.0.1 CPU: QCOM IMEI: NA KERNEL: Linux version 3.10.49-ga4dcc6d-00001-g733be9a (android-bld@CompSRV02) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #1 SMP PREEMPT Mon Jul 4 18:31:06 CST 2016 ERROR: Unknown/unsupported brand ! Log file saved to: LOG_8_09_2017_12_13_23.txt Time needed - 00:00:07 i don't find any port of this mobile |
09-08-2017, 12:16 | #5 (permalink) | |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Quote:
Br | |
09-08-2017, 14:14 | #7 (permalink) |
Member: 1068286 Status: Offline Thanks Meter: 182 | Finaly Unlock Done problem was driver Software engine version: 1.0.0.10543 Searching phone ... MODEL : QCOM SERIES 46 COMPILED DATE : Jul 4 2016 17:36:00 RELEASE DATE : May 15 2016 22:00:00 FIRMWARE INFO : MPSS.DPM.2.0.2.c1-00140-M8936FAAAANUZM-2.55917.1 IMEI : 014497XXXXXXXX-7 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; WORKING; SAVED: F2CBC6B90DE3B69171EA05092586D97F.bin UNLOCK CODE: N/A DONE; DOING EXTRA CALCULATION; AFTER UNLOCK YOU MUST RESTART THE PHONE MANUALLY; SIM_LOCK REMOVED ! RESET ! Log file saved to: LOG_8_09_2017_15_12_48.txt Time needed - 00:00:38 Thanks Daniel |
