08-24-2015, 02:08 | #1 (permalink) |
Major Poster Join Date: Sep 2012 Location: Sydney
Member: 1810103 Status: Offline Thanks Meter: 12 | Problem with Unlock Code Alcatel Pop 2 4045L [SOLVED] PID is confimed and correct PID was selected. Furious Team, please reply asap. |
09-21-2015, 00:41 | #2 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Treasure Island of the pacific
Member: 168090 Status: Offline Thanks Meter: 92 | Success Alcatel 4045L done unlocking with pack 5. Same driver and procedure as unlocking VF-895N Cheers. -blu |
The Following 2 Users Say Thank You to blu angel For This Useful Post: |
10-22-2015, 06:45 | #4 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Australia
Member: 177568 Status: Offline Thanks Meter: 146 | I can't seem to unlock this model. It looks like the phone gets connected in a different mode. Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (USB Composite Device) Preparing to enter download mode; Preparing to open COM98 Connecting; Init; Port opened; Phone detected (ZEUS Flash Device) Preparing to start flash mode; Log file saved to: LOG_22_10_2015_16_36_01.txt Time needed - 00:01:13 |
10-22-2015, 09:05 | #6 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Wrong drivers installed !!!! ZEUS Flash Device => SEMC drivers. MUST INSTALL ALCATEL ONES | |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
10-23-2015, 07:02 | #8 (permalink) |
Member: 177568 Status: Offline Thanks Meter: 146 | All good now Thanks: Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (USB Composite Device) Preparing to enter download mode; Preparing to open COM98 Connecting; Init; Port opened; Phone detected (Android HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM102 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22D4 IMEI: 8654xxxxxxxxxx-x PTH: 02 PTS: LHI PROV_ID: 4045L-2DVDAU1 SBTADDR: 948:59:4CB:77 SWIFIADDR: 948:59:4CB:78 HS_PN: SAA1B17ABB0C SSN: 1VKC01CNAKY0069 Work id: 038B9345 Setup 1; Done; Setup 2; Done; Uploading; Done; SECURITY: X5LHOVI0BG00 Size: 00000430 Backup saved to: 8654xxxxxxxxxx-x Checking the simlock; Magic ok; Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_23_10_2015_16_55_04.txt Time needed - 00:01:28 |
10-30-2015, 06:22 | #12 (permalink) |
Freak Poster Join Date: May 2010
Member: 1302063 Status: Offline Thanks Meter: 4 | Preparing to open COM204 Connecting; Init; Port opened; Phone detected (@oem267.inf,%qcomdevice90080%;ALCATEL HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM205 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22D4 IMEI: 8654XXXXXXXXX-X PTH: 02 PTS: LHI PROV_ID: 4045L-2DVDAU1 SBTADDR: 948:59:77:0B:2A SWIFIADDR: 948:59:77:0B:2B HS_PN: SAA1B17ABB0C SSN: 1VKC01CNAKY01XS Work id: 038B58EB Setup 1; Done; Setup 2; Done; Uploading; Done; SECURITY: X5LHOVI0BG00 Size: 00000430 Backup saved to: 86544502002016-1 Checking the simlock; Magic ok; Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_30_10_2015_15_14_58.txt Time needed - 00:00:55 Thanks FG TEAM |
