08-22-2013, 12:22 | #1 (permalink) |
Freak Poster Join Date: Aug 2004 Location: WORLDWIDE
Member: 78516 Status: Offline Thanks Meter: 62 | Problem unlocking alcatel ot 918 I have tried to read codes from alcatel OT 918. Here is the log: Code: Searching phone; Phone detected (@oem338.inf,%vcom_preloader%;PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on FTEAM USB Serial Port (COM249); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6573, E00 Sw version: MAUI.11AMD.W11.37.SP.V27.P18 Hw Version: JRD73_GIN_MODEM_GEMINI2_HW Reading phone info; IMEI: 860767-00-XXXXXX-3 Reading simlock info; Locked to: C1C-1C code_cat_n: 12345678 enabled: no tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:01:17 the ALCATEL is locked on orange france 208-01. Obviously, it rejects the MTK READER read codes. Yesterday, I succesfully unlocked the same model locked on an another operator. I 've even checked "perform direct unlock" . Does someone experience the same problem ? Is there a solution ? Thanks Best regards Last edited by tooko; 08-22-2013 at 12:29. |
08-23-2013, 11:12 | #3 (permalink) |
Member: 78516 Status: Offline Thanks Meter: 62 | problem solved hi, thank you very much .:hack3r2k:. and furious team for your great job, always supply us best solution. My problem solved with .:hack3r2k:. 's help on Skype. BR |
