04-24-2012, 05:24 | #1 (permalink) |
No Life Poster Join Date: Mar 2006
Member: 240043 Status: Offline Thanks Meter: 78 | Repair bb phones thanks alot http://forum.gsmhosting.com/vbb/f668...ongle-1463527/ |
04-24-2012, 15:25 | #2 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
This SO called box uses FREE available CFP to take your money for nothing RIM Wireless Device Command-Line Programmer Version 3.9.0.190 Copyright 2010 Research In Motion Limited Usage: CFP [-u<port>] [-g<GUID>|-ig] [-w<password>|-np] [-v<verbosity>] [-t<max connect timeout>] [-c<max command timeout>] [-sp] <command> <command> is one of HELP [<command>] INFO FLASHINFO FILEINFO <filename> LOAD <filename1> [filename2] [-v] [-p] WIPE [-F|-I] SAVEFS [-X] <filename> CSAVEFS <filename> NUKE [-A] FRESH ERASE <range> READ <range> [-A] <filename> CREAD <range> [-A] <filename> WRITE <range> <filename> [<offset>] [-v] WRITE <start address> <filename> [<offset>] [-v] HIS HOS GETHISMODE SETHISMODE HASHBOOTROM [<bootromfile> [<hwvfile>]] USBMS [-i<INFO> | -s<ENABLE> | -c<DISABLE>] PATRIOT [-o] <subcommand> [<arguments>] GETLOG [filename] <range> is one of <start address>-<end address> (start address < end address) <start address>,<length> (length > 0) All ad*******, lengths, and offsets are expressed in HEX. Also, <end address> is the address of the last byte in the range (e.g. <length> = <end address> - <start address> + 1) Verbosity Level: -vd Display nothing at all (output disabled) -v0 Display nothing other than progress -v1 Display errors -v2 Display errors and warnings (default) -v3 Display procedural steps -v4 Display protocol commands -v5 Display everything. Lots of chatter! USB Ports: to use this feature, configuration with USBPortMapper.exe is required. Please see 'USBPortMapper.exe HELP' for more information. Br | |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
04-26-2012, 07:04 | #3 (permalink) | |
Member: 240043 Status: Offline Thanks Meter: 78 | Quote:
Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 8 | 10-31-2012 20:17 |
Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-16-2010 05:52 |
