06-29-2016, 13:58 | #1 (permalink) |
Freak Poster Join Date: Mar 2016 Location: united kingdom
Member: 2549105 Status: Offline Thanks Meter: 4 | Samsung e1200 unlock problem I'm having problems reading unlock codes for Samsung e1200 using FG Samsung Module. I cant get the software to detect the handset and the software just times out. Im connecting directly to pc using e210 cable Any help please??? |
07-11-2016, 09:54 | #3 (permalink) |
Member: 2549105 Status: Offline Thanks Meter: 4 | I have tried this method and still cannot get the handset to connect. I keep getting the following message: ERROR: SCI USB2Serial port not found! BE sure the drivers from support were installed; I have installed the Spreadtrum drivers from the drivers folder but when I connect the e210 cable to the handset it comes up with battery fully charged message before I can press the ok button and insert the battery. Thank You. |
07-11-2016, 12:19 | #4 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Because you do it wrong. Must press OK, insert cable,and only when the sw is looking for the phone you insert the battery Br | |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
07-11-2016, 14:21 | #5 (permalink) |
Member: 2549105 Status: Offline Thanks Meter: 4 | Thankyou for your support. Turned out the fault was a damaged e210 cable. Have fixed cable and is now working correctly. |
The Following User Says Thank You to apkfone For This Useful Post: |
