08-24-2010, 09:09 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: pakistan
Member: 898041 Status: Offline Sonork: 100.1593459 Thanks Meter: 549 | Soluttion here u fone g2158 durring unlocking and restoring if reset button not work If durring unlocking and restoring reset button not work, then use a needle durring oppration. When software says press power then needle attach in reset button pin and board no need press button your problem solve. I am testing 100%. Test and send result. |
08-24-2010, 10:38 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Al-Ahsa Saudi Arabia Age: 35
Member: 253510 Status: Offline Sonork: 100.1672352 Thanks Meter: 3,534 | For those who face problem during restore! Restore button not wokr only use 115200 speed then check, all will b ok! NO NEED TO OPEN PHONE! B SURE UR PHONE BATTERY IS CHARGED! Br |
The Following User Says Thank You to .::M Irfan::. For This Useful Post: |
08-24-2010, 10:48 | #3 (permalink) |
Member: 253510 Status: Offline Sonork: 100.1672352 Thanks Meter: 3,534 | Just unlock a g2158, using high buadrate 962100! Dead during unlok! Then i try to restore but restore button not work in high speed 962100! Then i have try again with 115200 speed and everythin goes well! Check and post result! Only use 115200 speed! Connect phone powered on ! Start auth ! SW Ver: REL_P1.1PU01V01.06 Imei: 358892032864892 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00C2:22A7 Reading ... Saved: HUAWEI_358892032864892_REL_P1.1PU01V01.06_02.41.15 _24.08.2010_PARTIAL.bin Erasing ... Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00C2:22A7 Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:34 Br |
08-31-2010, 08:37 | #5 (permalink) |
No Life Poster Join Date: Nov 2006 Location: *P*A*K*I*S*T*A*N
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | If any one is unable to press rest button or the reset button is not working while you are on the second stage (Phone dead) You need the following steps 1. Open the phone, Unplug one of the battery points(+ or - ) 2.Give the restore file by selecting restore 3.soft will ask to press power on 4.now attach the disconnected point that was desoldered or detached and press power on button for few seconds 5.Remember to sold the RX point (Not connect it with the needle ) 6.when soft says (after press ok , push the reset button near Sim connector), again disconnect battery and connect again and press the power button 7.phone will be connected and restored 8.Now again repeat the unlock procedure 9.This time on second stage repeat the step number 4. and you are done |
09-02-2010, 18:13 | #8 (permalink) | |
No Life Poster Join Date: Aug 2008 Location: pakistan
Member: 828294 Status: Offline Sonork: 100.1615866 Thanks Meter: 124 | Quote:
plz clear the step 5, needle means tp pin? or else.....and how to sold rx?? | |
09-18-2010, 15:11 | #9 (permalink) |
No Life Poster Join Date: Mar 2008
Member: 725834 Status: Offline Thanks Meter: 921 | g2158 unlock and tp gide here,,,,,,,,,,,,,saram ali download link,,,,,,,, G1158_TP__.jpg - 4shared.com - photo sharing - download image |
10-09-2010, 13:56 | #10 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: Islamabad--Pakistan
Member: 194128 Status: Offline Thanks Meter: 303 | Quote:
+ve point attached it | |
02-29-2012, 08:52 | #14 (permalink) | |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Quote:
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
