07-19-2016, 19:18 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: algerie
Member: 259512 Status: Offline Thanks Meter: 33 | StarTrail 2 unlock problem Searching Huawei phone COM ports... OK Application port: Diagnostics port: COM155 Driver version: 2.0.6.601 OEMSBL running: 76XXU-109808-USNEKQL Checking bootloader status... not running! Connecting to server... OK Sending data to server... OK Reading data from server... OK Sending data to server... OK Reading data from server... OK Sending data to server... OK Reading data from server... OK Uploading bootloader... OKOK Starting bootloader... OK Disconnecting from server... OK Initializing flash... OK Reading phone info... OK Decrypting IMEI... OK Reading sensitive data... OK Reading bootloader lock status... OK Model name: Huawei U8xxx NAND series IMEI: 8618950hhhhhhhhh 2016-07-19 19:15:57.109 Start unlocking procedure (861895xxxxxxxxxxxxx) Connecting to server... OK Sending data to server... OK Reading data from server... OK Checking bootloader status... not running! Disconnecting from server... OK No response ! |
07-20-2016, 16:12 | #3 (permalink) |
Member: 259512 Status: Offline Thanks Meter: 33 | same problem with flycaptain 2016-07-20 16:12:07.250 Open port COM155 (DBAdapter Reserved Interface (COM155))... 2016-07-20 16:12:07.375 Connecting to server... 2016-07-20 16:12:08.093 Connected! 2016-07-20 16:12:08.093 Read data from server... 2016-07-20 16:12:10.125 Read data from server success! 2016-07-20 16:12:16.656 Phone authorize start 2016-07-20 16:12:16.921 Phone authorize fail! 2016-07-20 16:12:16.921 ERROR! No response! |
