04-13-2013, 14:56 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Nigeria Lagos
Member: 1014618 Status: Offline Sonork: 100.1637137 Thanks Meter: 110 | steps to flash ORANGE_BOSTON successfully |
04-14-2013, 05:01 | #3 (permalink) |
Member: 1014618 Status: Offline Sonork: 100.1637137 Thanks Meter: 110 | pls wat i found there is unlocking guide. D problem i ve is when i want 2 flash, afta i ve extracted d file, when i want 2 choose file it only highlight 1 file(size is 3kb) is dat d right file pls? Pls hack n odas |
04-14-2013, 11:29 | #4 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Don't use download manager and file will download correctly Br | |
04-14-2013, 19:45 | #5 (permalink) |
Member: 1014618 Status: Offline Sonork: 100.1637137 Thanks Meter: 110 | 10ks but i download it correct.wen i wan 2 use d SUTL setup 2 update it did nt highlight d winrar file n wen i extracte, d files are many in d folder BUT wen i browse 2 select d file 4rm same folder, it shows only 1 file with size 3k. If process is ok wich optn should i choose is it erase flash or wat? |
04-15-2013, 07:27 | #6 (permalink) | |
Yes you must select .mlf and flash it Br | |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
