Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 10-30-2007, 20:04   #1 (permalink)
momayaz's Avatar
Member: 135532
Thanks Meter: 17
still same problem on all pc
dear supporter i have problem when flashing any device with
RJ45 the handle is invaled i try every thing even format and install fresh copy of XP-SP2 i search the whole site i didnt find any solution for my problem
but when plug the box to laptop every thing work fine and smooth
and even faster
i hope to solve my problem
thank you
B.R.
Old 10-30-2007, 20:06   #2 (permalink)
momayaz's Avatar
Member: 135532
Thanks Meter: 17
this is a picture for the error
thanks
Old 10-31-2007, 09:59   #3 (permalink)
momayaz's Avatar
Member: 135532
Thanks Meter: 17
even i try to connect throu com1 i have this problem
picture attached
B.R.
Old 10-31-2007, 10:35   #4 (permalink)
mamirza's Avatar
Member: 300540
Thanks Meter: 103
and even faster
thank you
B.R.
Seems there is low pc's usb power !
Pls read here.
BR.
Old 10-31-2007, 10:42   #5 (permalink)
momayaz's Avatar
Member: 135532
Thanks Meter: 17
the problem of com1 has been solved by adjusting the speed to 115200
B.R.
Old 10-31-2007, 10:44   #6 (permalink)
momayaz's Avatar
Member: 135532
Thanks Meter: 17
Pls read here.
BR.
ok my friend how to check the usb power low or not
any advice well help
thanks in advance
B.R.
Old 10-31-2007, 11:02   #7 (permalink)
momayaz's Avatar
Member: 135532
Thanks Meter: 17
i change the usb cable and usb port its the same problem
Old 12-02-2007, 09:03   #8 (permalink)
momayaz's Avatar
Member: 135532
Thanks Meter: 17
stil same problem i try every thing you can imagin but no succses
b.r.
Old 12-02-2007, 17:43   #9 (permalink)
.:hack3r2k:.'s Avatar
Member: 15022
Sonork: 100.53452
Thanks Meter: 61,564
b.r.
Can exactly tell HW config, OS version and sws installed ?
Old 12-03-2007, 09:08   #10 (permalink)
momayaz's Avatar
Member: 135532
Thanks Meter: 17
here is some picturs
if you need some pic tell me what you need and i'll get it for you
b.r.
Old 12-03-2007, 09:34   #11 (permalink)
Member: 438551
Thanks Meter: 36
The reason could be
- 1) USB HUB problem ,
- 2) USB drivers conflict,
- 3 ) Your PC motherboard problem ( burned usb part or something like this) .
Old 12-03-2007, 09:46   #12 (permalink)
bronce's Avatar
Member: 488875
Sonork: 100.1626294
Thanks Meter: 1,129
better to used another pc..and post result.......
Old 12-03-2007, 09:52   #13 (permalink)
momayaz's Avatar
Member: 135532
Thanks Meter: 17
@bronce tow pc's allready check
i google it (the handle is invalid) alote of people says and solved by reg and somthing like that
so i think its reg problem
b.r.
Old 12-03-2007, 10:00   #14 (permalink)
momayaz's Avatar
Member: 135532
Thanks Meter: 17
now i'll make full update for windows and then try it may be its solved
Old 12-03-2007, 11:17   #15 (permalink)
momayaz's Avatar
Member: 135532
Thanks Meter: 17
no luck at all i update the windows and still same problem
6120c white screen -replaced avilma and betty-still same problem-help zonetrichur Nokia Hardware & Hardware Repair 9 07-20-2010 11:39
hwk still same problem chand_gee HWK 6 03-30-2009 10:06
6131 imei 1234--wrote rpl-still same problem zonetrichur Nokia Base Band 5 ( BB-5 ) 2 10-25-2008 18:30
Formatted N95 Big But Still Same Problem shola5 MC-Tool 6 03-13-2008 10:02
Samsung X480 Reboot After Every Incoming/outgoing Call-flashed-still Same Problem zonetrichur UST Pro II 0 06-16-2007 19:21
Page generated in 0.22648 seconds with 10 queries
