04-19-2010, 16:03 | #1 (permalink) |
Insane Poster Join Date: Feb 2008
Member: 714627 Status: Offline Thanks Meter: 11 | Strange install problem I have installed FG onto the computer, but failing when trying to run the modules. - Running maintenance is fine, i can rread serial, generate licence and change packs - When i run any module it says "Card reader(s) not found" The fact that Maintenance.exe is fully working suggests that the card is inserted correctly, but it just will not run the modules! In Control Panel the box is being detected after installing the FG by steve drivers! Any help or guides? I have searched support but can only come up with people who have the card not quite inserted problems. This would be worth a try but the fact that maintenance recognises it suggests otherwise? Many thanks TP |
04-23-2010, 14:52 | #4 (permalink) |
Registered User Join Date: Mar 2008
Member: 737047 Status: Offline Sonork: 1614214 Thanks Meter: 31 | dear your window will may be currupt or ur this exe file also currupt so change ur exe bye the removing and installing procedure then run it again and click the admnistrator and check it? |
04-23-2010, 14:59 | #5 (permalink) |
No Life Poster Join Date: Oct 2009 Location: FuriouSGold Age: 18
Member: 1144248 Status: Offline Sonork: 100.1574721 Thanks Meter: 3,936 | Your problem it's because you are trying to open softwares that are not allowed with the pack loaded in dongle. read FAQ |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
