01-05-2018, 10:57 | #5 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | This is an Qualcomm Snapdragon 625. By who is manufactured ? Can post an imei ? Br |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
03-13-2018, 13:37 | #7 (permalink) |
Junior Member Join Date: Mar 2018
Member: 2820623 Status: Offline Thanks Meter: 0 | I'm searching for the same thing,any sort of aap unlock, or even better any custom ROM or trick to make fast boot work as everyone I've seen has said unlike the original Alcatel version you at least CAN get it into fast boot mode but the bootloader is locked, can't flash a TWRP image but if anyone has the kernel source for the revvl plus that could help. |
07-01-2018, 22:00 | #11 (permalink) |
Crazy Poster Join Date: Sep 2010 Location: honduras
Member: 1386786 Status: Offline Thanks Meter: 16 | Using the diagport is possible this can enabled using app shortcut master , diagnostic and other ports are enabled can you read and write qcn and imei, maybe some body check if is possible unlock from this way |
01-10-2019, 16:07 | #15 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
The above shortcut is obviously not for unlocking, but to activate the diag ports for possible unlocking or frp removal. | |
The Following User Says Thank You to BillA For This Useful Post: |
