05-30-2010, 03:17 | #1 (permalink) |
No Life Poster Join Date: Apr 2009
Member: 1012165 Status: Offline Thanks Meter: 116 | treo 680 unlock help |
The Following User Says Thank You to tonywireless For This Useful Post: |
05-30-2010, 03:56 | #2 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Philippines
Member: 329609 Status: Offline Thanks Meter: 245 | Code: Q: I'm trying to unlock new NECs and use TREO module TXT to code features but i'm allways getting 'Error..' or 'ERROR: 00' why !? A: First of all dongle must be upgraded with PACK 2. 1. Upload to the phone using Bluetooth or USB cable TreoUnlock_H2K_PRC_APPLET_BETA.rar from support. 2. Once this palm application installed please run it from phone (be sure you turn radio off before) 3. If all went ok you should notice some text shown on phone display similar to unlock data send the unlock data to [email protected] --8<-- 777QJSMQXG WQIIEL7M73 33LN6FJXIF 402IDHCCHJ TQ --8<-- 4. Now open TREO module, select TXT TO CODE option and enter obtained data like 777QJSMQXGWQIIEL7M7333LN6FJXIF402IDHCCHJTQ 5. If all ok you will get the code. Q: I just got unlock data from a TREO. How i get code ? A: 1. Open TREO module, select TXT TO CODE option and enter obtained data like 777QJSMQXGWQIIEL7M7333LN6FJXIF402IDHCCHJTQ 2. If all ok you will get the code. |
The Following 2 Users Say Thank You to kungpaoski For This Useful Post: |
05-31-2010, 04:48 | #3 (permalink) |
Member: 1012165 Status: Offline Thanks Meter: 116 | when i put a simcard into this treo 680 it does not request for code,it is just still the same way it is when the simcard is not inserted somebody pls reply me before i request for the code so i dont waste my code,is there a code or a way of knowing the lock status of this phone i.e to know if it is locked or not?thanks in advance |
05-31-2010, 09:26 | #4 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
You must type the code exactly as u see it. Br | |
05-31-2010, 12:59 | #5 (permalink) |
Member: 329609 Status: Offline Thanks Meter: 245 | How to enter codes Model: Treo 600, 650, 680 (Centro), 750 1. Insert an unauthorized Sim Card and turn ON your phone 2. It will then say "Your phone cannot be used with this SIM card" 3. Click OK 4. Click dial pad tab, bottom of the screen far left 5. Using stylus enter *#*#Unlock Code# 6. Press the green button 7. It will then say “The SIM Lock has been removed from the phone" b.r. |
05-31-2010, 13:38 | #6 (permalink) |
Member: 1012165 Status: Offline Thanks Meter: 116 | bro when i put an unathorized simcard and put the battery the phone just powers on and at the left top corner the phone diaplays phone off so is there any problem with that or how do i make it write phone on when i sent the TreoUnlock_H2K_PRC_APPLET_BETA to the phone it did not display the code instead it displayed the unlock process may take up to 20 seconds pls be patient done pls send the unlock data memo at hack3r2k.com press home key to exit. i did not see any code pls what do i do |
05-31-2010, 17:38 | #7 (permalink) | |
Q: I'm trying to unlock new NECs and use TREO module TXT to code features but i'm allways getting 'Error..' or 'ERROR: 00' why !? A: First of all dongle must be upgraded with PACK 2. 1. Upload to the phone using Bluetooth or USB cable TreoUnlock_H2K_PRC_APPLET_BETA.rar from support. 2. Once this palm application installed please run it from phone (be sure you turn radio off before) 3. If all went ok you should notice some text shown on phone display similar to unlock data send the unlock data to [email protected] --8<-- 777QJSMQXG WQIIEL7M73 33LN6FJXIF 402IDHCCHJ TQ --8<-- 4. Now open TREO module, select TXT TO CODE option and enter obtained data like 777QJSMQXGWQIIEL7M7333LN6FJXIF402IDHCCHJTQ 5. If all ok you will get the code. Br | |
05-31-2010, 19:32 | #8 (permalink) |
Member: 1012165 Status: Offline Thanks Meter: 116 | Sir this is the code i got from the phone 777QJWGX3AWA2L54ZRHCT3K5S2DDRO5JPW2QLRBGV4 when i paste it on treo module this is what i get pls what could be the problem? Starting ... Please wait ! > ERROR: 07 Time needed - 00:00:20 do i need to plug the phone wit its usb to the p.c usb or the furious gold usb?before i get the code Last edited by tonywireless; 05-31-2010 at 19:39. |
05-31-2010, 20:14 | #9 (permalink) |
Member: 1012165 Status: Offline Thanks Meter: 116 | when i put in a simcard in the phone then put press the power button to off the phone and on it back to put it in phone mode it displays network search and after that says no network,i taught it was meant to request for a code or "Your phone cannot be used with this SIM card"? so what is the problem note i have not put in any code in the phone cos i've not got any code since after pasting string from memo even without simcard it still shows no service Last edited by tonywireless; 05-31-2010 at 20:23. |
06-01-2010, 06:45 | #11 (permalink) |
Member: 1012165 Status: Offline Thanks Meter: 116 | when i put a test card it still does network search and finally shows no service even without any simcard it still does network search and finally shows no service.is there any way i can confirm if this phone has been unlocked before so i can know if its a hardware broblem i mean something like a code or a place on the phone that reads the unlock status thanks in advance |
06-01-2010, 09:27 | #12 (permalink) | |
Do you avtually raed what we wrote ? Or you like just keep posting and posting without reading ? You must transfer credits to your dongle, we posted procedure and string you get from phone must be decoded using TREO.exe but offcourse after credits transfered to box !!!!! Anyway you code is MODEL: TREO 680 IMEI: 35270501003087 NCK: *#*#53799147# Br | |
06-01-2010, 11:41 | #13 (permalink) |
Member: 1012165 Status: Offline Thanks Meter: 116 | thanks for ur response and code but when i put an unauthorized simcard it does not display . Insert an unauthorized Sim Card or "Your phone cannot be used with this SIM card it just shows searching and after that no service even without a sim card it still shows the same thing.so in this case how do i put in the code pls waiting for a quick response |
06-01-2010, 17:21 | #14 (permalink) |
Member: 1012165 Status: Offline Thanks Meter: 116 | pls help me when i put in the code given to me by hack3r2k it tells me locked sim lock has not been removed pls what could be the problem (i have swithed on the radio and without simcard)the owner of the phone needs it back and i dont want all my effort to be in vain |
