01-31-2009, 23:57 | #1 (permalink) |
Product Supporter Join Date: Aug 2008 Location: ...=-Inside FASTDONGLE-=...
Member: 838185 Status: Offline Thanks Meter: 26 | u880 unlocking problem.... I want to unlock my u880 to your Latest Version, but Here's my logs... Code: Software engine version: 1.0.0.898 Searching phone ... MODEL : U880 COMPILED DATE : Jun 22 2006 09:44:00 RELEASE DATE : Jul 3 2005 16:00:00 FIRMWARE INFO : U880-MSM6250-V11a-JUN-20-2006-H3G-DE IMEI : 35705000779568-9 BLUETOOTH ADDR : 2D 95 0C 56 12 00 MEMORY ID : 0098:0079 MEMORY NAME : toshiba_ty9000ac10aobg MEMORY INFO : 0200:0020:1980 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] MODULE ERROR IMEI: [OK] 3570568900 BLUETOOTH ADDR: [OK] 2D950C561200 PLAYING MUSIC ... WAIT; DOING CONFIG; INJECTING VODKA; INJECTING JUICE; DRINKING; Error ... ! Time needed - 00:01:00 tia |
02-01-2009, 03:19 | #2 (permalink) | |
Banned Join Date: Jul 2005 Location: Philippines Age: 53
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | Quote:
02-01-2009, 04:36 | #3 (permalink) |
Product Supporter Join Date: Dec 2004 Location: Furious Team ... GPGIndustries Age: 45
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,045 | exactly flash with special SW then try Again All should be ok By the way have you press Power when phone ask you to do that ??? |
02-01-2009, 10:35 | #4 (permalink) |
Member: 838185 Status: Offline Thanks Meter: 26 | hello... thanks for those who replied... but what exact FW do i put on the unit????? cause i have dial up connection only here in my place.... I put this Special FW came on support >>> U880-V10b-wm-FEB-22-2006-H3G-IT+3.sex here my logs again... Code: Searching phone ... MODEL : U880 COMPILED DATE : Jun 22 2006 09:44:00 RELEASE DATE : Jul 3 2005 16:00:00 FIRMWARE INFO : U880-MSM6250-V11a-JUN-20-2006-H3G-DE IMEI : 357050 BLUETOOTH ADDR : 00 12 56 0C 95 2D MEMORY ID : 0098:0079 MEMORY NAME : toshiba_ty9000ac10aobg MEMORY SIZE : 105MB INIT FLASHING ENGINE ... OK; READING NV ... READY... UPLOADING STARTED; WORKING IN NORMAL MODE; Error ... ! Time needed - 00:00:07 |
02-01-2009, 12:01 | #6 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Pakistan
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | Quote:
just add me on messenger and u will see ur phone working and unlocked perfect with furious software | |
02-01-2009, 13:53 | #9 (permalink) |
No Life Poster Join Date: Dec 2000 Location: J.A.U - Just Another Unlocker Age: 43
Member: 2878 Status: Offline Thanks Meter: 9,123 | i give you a better tip... flash your U880 with the v11 free files and lg free flasher, than unlock with furious. 1.) it works (tested many times by me) 2.) you dont need to switch from pack5 to pack1 (for flashing) and back to pack5 for unlocking you can find the files here in forum. i use the v11 files for repair downgraded u880 phones... test and post result (i think its the fastest and best way) br. hari |
02-01-2009, 14:05 | #11 (permalink) |
Member: 2878 Status: Offline Thanks Meter: 9,123 | i give you a better tip... flash your U880 with the v11 free files and lg free flasher, than unlock with furious. 1.) it works (tested many times by me) 2.) you dont need to switch from pack5 to pack1 (for flashing) and back to pack5 for unlocking you can find the files here in forum. i use the v11 files for repair downgraded u880 phones... test and post result (i think its the fastest and best way) br. hari ps: here is all you need: http://forum.gsmhosting.com/vbb/show...U880+V11+flash .) use original lg flasher (in this thread) .) use the flashfiles in this thread (change country if needed) .) unlock with your furious you will see it works! |
The Following User Says Thank You to oOXTCOo For This Useful Post: |
02-01-2009, 16:26 | #14 (permalink) | |
Member: 838185 Status: Offline Thanks Meter: 26 | Quote:
Code: 2) appropriate media v10b_wm (download from here ) can anybody have this file pls.... tia | |
02-01-2009, 17:20 | #15 (permalink) | |
Member: 2878 Status: Offline Thanks Meter: 9,123 | Quote:
i can post you the files, but at monday when iam back in my shop. i dont have this files at home... but iam shure you can find original v11 files here in forum. they work to, you dont need exact this files for unlocking. just use original flasher and original v11 files. but i post you the files monday if nobody other post it before... | |
u880 unlocking problem | kwamena | FuriousGold | 5 | 03-01-2008 13:54 |
lg u880 unlock problem | burraq | FuriousGold | 4 | 11-07-2007 16:58 |
u880 unlock problem?? | runner30 | LG | 1 | 09-14-2007 13:50 |
u880 unlock problem pl help me | ruvanw1979 | FuriousGold | 5 | 08-28-2007 04:19 |
u880 unlock problem | FoneFixUk | LG | 2 | 05-17-2007 22:12 |
