10-11-2012, 13:24 | #5 (permalink) |
No Life Poster Join Date: Apr 2008 Location: INSIDE OCLHASHCAT
Member: 751235 Status: Offline Sonork: 100.1662008 Thanks Meter: 526 | me too here is logs Searching Huawei phone COM ports... not found ! Searching Android USB Interface... OK Checking bootloader status... not running! Connecting to server... OK Sending data to server... OK Reading data from server... OK Sending data to server... OK Reading data from server... OK Uploading bootloader... OK Starting bootloader... failed! Server disconnected! Product name: MSM7627A Error! Open USB driver failed ! |
10-25-2012, 18:19 | #7 (permalink) |
Crazy Poster Join Date: Jan 2005 Age: 50
Member: 109518 Status: Offline Thanks Meter: 3 | hi i have a u8665 i try to pass with pack 7 i put fast mode the screm is purple and then i have this Searching Huawei phone COM ports... OK Application port: COM262 Diagnostics port: COM19 Error! DBAadapter Reserved Interface driver ver. 2.0.6.601 required, please download from support and install where can find this driver on support if someone have idea thankl |
10-25-2012, 21:43 | #8 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Br | |
10-25-2012, 21:44 | #9 (permalink) | |
This phone must be unlocked from DOWNLOAD MODE not FAST BOOT | |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
04-13-2013, 10:16 | #10 (permalink) |
Freak Poster Join Date: Jul 2007 Location: some where Age: 41
Member: 545608 Status: Offline Thanks Meter: 25 | Searching Huawei phone COM ports... OK Application port: COM191 Diagnostics port: COM197 Checking bootloader status... not running! Connecting to server... OK Sending data to server... OK Reading data from server... OK Sending data to server... OK Reading data from server... OK Sending data to server... OK Reading data from server... OK Uploading bootloader... OK Waiting phone to be ready ... OK Starting bootloader... OK Disconnecting from server... OK Initializing flash... OK Reading phone info... OK Decrypting IMEI... OK Reading sensitive data... OK Model name: Huawei U8815/U8665 IMEI: 863496017746591 SIM Lock status: locked (NCK lock) 2013-04-13 09:15:09.515 Start unlocking procedure (863496017746591) Connecting to server... OK Sending data to server... OK Reading data from server... OK Checking bootloader status... OK Initializing flash... OK Reading phone info... OK Decrypting IMEI... OK Reading sensitive data... OK Creating backup of Sensitive Data... OK Backup saved to file "C:\Program Files\FuriouS-Gold\pack 7\Backup\863496017746591_2013-04-13_091522.fhb" Sending data to server... OK Reading data from server... OK Writing flash... OK Reseting unblock retry counter... OK Sending data to server... OK Reading data from server... OK Disconnecting from server... OK 2013-04-13 09:15:25.703 Done! |
