Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriouS TeaM Products
FuriouS TeaM Products FuriouS GOLD Support Area
Old 12-08-2008, 06:29   #1 (permalink)
Member: 161823
Unsecure port opening failed !
Restoring file v4[1].2.1.79_P2.3.0.7.sfi from C:\Documents and Settings\sa\Desktop\sfi\8800\
Booting usb device ...
Setting up usb device ...
Loading main os for device ...
Waiting ...
ERR_MSG: OS programming failed !
Time needed - 00:04:43
how to solve this ?
br
denny86
Old 12-08-2008, 08:20   #2 (permalink)
.:hack3r2k:.'s Avatar
Member: 15022
Sonork: 100.53452
Waiting ...
how to solve this ?
br
denny86
8800 isnt supported.
Old 12-08-2008, 08:25   #3 (permalink)
Member: 161823
ok let see
br
denny86
Old 01-13-2010, 17:23   #4 (permalink)
Member: 1203113
What if this happens with an 8330 that IS supported?
Old 01-13-2010, 18:59   #5 (permalink)
Member: 1203113
Unsecure port opening failed - BBCFPCOM not registered
Ok, I have been running into this error when rewriting the PIN on some 8330c's with MEID's while ESN based 8330's worked fine.
I tried using MML and was receiving an error that BBCFPCOM wasn't registered. So I registered BBCFPCOM via:
[DRIVE LETTER]:\Windows\System32\RegSvr32 C:\MML\BBCFPCOM.DLL
from a command prompt.
Then, I noticed that when the replacement SFI file was being loaded in the unlocker, the phone was also rebooting. So, instead of disconnecting it like requested, I left it connected and waited for it to reboot and THEN I hit OK. The phone was detected, connected, finished and worked.
I'm not sure which of the two variables made the difference since I still get the "unsecure port opening failed" message, although I would put my money on it having been a timing issue. I think it's safe to say though, that if you are getting other errors related to BB communications, it's best to fix those ASAP.
The odd thing is that I haven't made any changes to the system, as far as I can remember, that would have caused a problem with BBCFPCOM being registered...
Old 01-13-2010, 19:50   #6 (permalink)
FTEAM_MODERATOR's Avatar
Member: 1144248
Sonork: 100.1574721
You must replace old drivers with new ones
Regards
Furious Support
Old 01-13-2010, 20:24   #7 (permalink)
Member: 1203113
Can you provide a direct link for the updated drivers?
Do the updated drivers cause issues with any of the older equipment?
Port opening failed and no operations can be executed on it ! fantomasv FuriouS TeaM Products 6 03-06-2010 10:53
Z130 unlock always USB port open fail Singh05 FuriouS II 58 03-09-2006 21:51
C 60 java port open yankee S-Gold Based Phones 0 11-07-2003 20:40
Page generated in 0.46145 seconds with 11 queries
