01-28-2010, 13:29 | #1 (permalink) | |
No Life Poster Join Date: Jul 2002 Location: Little apt called Alhambra
Member: 13748 Status: Offline Thanks Meter: 84 | VE385 Bad codes Quote:
This are codes readed by box, but dosenīt work. After calculation with server, this is the working code: 93403410. Maybe a bug or unsupported version? Best regards. P.D. Sorry for double post in other section. | |
01-28-2010, 15:57 | #2 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Quote:
ENTER CODE(S) NOW ! DO NOT RESTART THE PHONE ! IF PHONE DOESN'T ASK ANY CODE OR YOU RESTART IT THEN REPEAT THE OPERATION ! Means you must enter those codes before restarting phone else offcourse wont work since our soft replaces them with its own. From same reason server ones wont be same. So next time enter restricted sim and when np code asked use our sw and enter the shown codes. Br | |
01-28-2010, 17:43 | #4 (permalink) | |
Member: 13748 Status: Offline Thanks Meter: 84 | Quote:
Regards. | |
01-29-2010, 14:22 | #5 (permalink) |
No Life Poster Join Date: Oct 2009 Location: FuriouSGold Age: 18
Member: 1144248 Status: Offline Sonork: 100.1574721 Thanks Meter: 3,936 | Weird, it's from Yoigo right? Try to do factory settings on phone and retry, maybe some problem... Regards Furious Support |
01-29-2010, 16:45 | #8 (permalink) |
Member: 13748 Status: Offline Thanks Meter: 84 | The procedure was: I click on address bar of IE and went to Unlockbase.com Clicked on "Imei Unlock" Select Service "Motorola (Europe Timezone) Select Model Write IMEI And finally click in "ORDER" And some minutes later I found the code in my Inbox. That was the exactly procedure as you asked me so kind. Best regrads heheheheheehe |
01-29-2010, 19:26 | #10 (permalink) | |
Member: 13748 Status: Offline Thanks Meter: 84 | Hello, Sure, the code in in the first post. Quote:
who can propose me solution for bad code in v56 | ashvin | SwS_SaG_BoX | 9 | 08-10-2006 14:00 |
Solution for enter code network in benq after try bad code | .:Morpheus:. | Various | 4 | 09-02-2005 00:30 |
bad codes | CyberKareca | Phone Unlocking Codes & Maps | 4 | 03-01-2003 19:04 |
bad codes | CyberKareca | Phone Unlocking Codes & Maps | 7 | 03-01-2003 12:15 |
Sagem 939 4.1M perm.blocked after bad code entered | scum | Infineon C16X M51 & ARM7 M52 BASED | 3 | 06-21-2001 19:10 |
