04-02-2015, 20:33 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: CIEGO DE AVILA ,CUBA
Member: 1176958 Status: Offline Thanks Meter: 158 | verykoool i129 unlock not done please help For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (SCI USB2Serial) Preparing to sync; Port opened [COM50]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; please i need help with this hansed everytimei try to unlock soft the phone dosent goes futher only Syncing;...... phone is from movistar also y try to flash form firmware downloaded form support but still cant flash the phone stay on the step on sof Syncing ;.... please help custumer waiting thanks in advance |
04-02-2015, 22:08 | #2 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Br | |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
04-03-2015, 17:36 | #3 (permalink) |
Member: 1176958 Status: Offline Thanks Meter: 158 | Unlock done choosing S300(1) thanks furious team Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (SCI USB2Serial) Preparing to sync; Port opened [COM140]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6531 FdlStat: 0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00EF:0040:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: NONE BT ADDR: 59:21:19:22:04:65 SW IMEI[0]: 353159-06-556730-4 SW IMEI[1]: 352751-01-952326-7 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON FIXED NV BASE: 303B0000 Reading NV; NV saved to : NV_000000-00-000000-0_353159-06-556730-4_65310001_3_04_2015_12_34_00.spd IMEI: 353159-06-556730-4 UNLOCK CODE: NONE Re-programming; NV programmed; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_3_04_2015_12_34_22.txt Time needed - 00:00:33 |
The Following User Says Thank You to yaro_rguez For This Useful Post: |
