01-21-2017, 18:03 | #1 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Kampala,Uganda
Member: 2294589 Status: Offline Thanks Meter: 116 | XOX WAVE XX unlock needed For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem161.inf,%dc_diag%;SPRD U2S Diag) Preparing to sync; Port opened [COM31]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6531 FdlStat: 0000 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00C8:0060:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: NONE BT ADDR: 11:16:48:09:13:20 SW IMEI[0]: 862556-02-946822-8 SW IMEI[1]: 862556-02-967622-6 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON FIXED NV BASE: 303C0000 Uncompressing; Done; Re-programming; FLS programmed; Done; Remove battery and cable; Log file saved to: LOG_21_01_2017_19_57_20.txt Sir this phone still showing dont support his sim What is the solution sir? |
01-26-2017, 10:16 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | You use an old version or wrong m,odel selected. Soft should display the unlock code for it Br |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
10-09-2019, 17:17 | #3 (permalink) |
No Life Poster Join Date: Apr 2008 Location: nigeria
Member: 757064 Status: Offline Sonork: 11111111 Thanks Meter: 365 | XOX-WAVE XX SUCCESSFULL UNLOCK DONE Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem90.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM36]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6531:0000 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00C8:0060:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: NONE BT ADDR: 14:00:37:11:13:20 SW IMEI[0]: 862556-02-932091-6 SW IMEI[1]: 862556-02-952891-4 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON FIXED NV BASE: 303C0000 Reading NV; NV saved to : NV_000000-00-000000-0_862556-02-932091-6_65310000_9_10_2019_17_05_06.spd IMEI: 862556-02-932091-6 UNLOCK CODE: *#855818*# Re-programming; NV programmed; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_9_10_2019_17_05_49.txt Time needed - 00:00:57 |
The Following 2 Users Say Thank You to skyulock For This Useful Post: |
