03-10-2014, 21:58 | #1 (permalink) |
Major Poster Join Date: Jan 2014 Location: Slovakia
Member: 2106189 Status: Offline Thanks Meter: 0 | Vodafone 555 flashing I can't connect it to PC: Make your handset power off, plug in the UART cable! Product: Vodafone555 Load DA file... Load AUTH file... Load flash image file... Start to connect the handset, keep pressing the power on key! Flash handset image failed! Error Code: 4084 Please double check the cable and handset connection! Try it again! I used microUsb cable |
03-11-2014, 13:09 | #7 (permalink) | |
Member: 2106189 Status: Offline Thanks Meter: 0 | Quote:
http://imageshack.com/a/img42/2400/om3x.jpg | |
03-11-2014, 21:56 | #8 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,552 | Quote:
Br | |
03-11-2014, 23:00 | #9 (permalink) |
Member: 2106189 Status: Offline Thanks Meter: 0 | Hello Now I tried it on Windows XP, same problem: Make your handset power off, plug in the UART cable! Product: Vodafone555 Load DA file... Load AUTH file... Load flash image file... Start to connect the handset, keep pressing the power on key! Flash handset image failed! Error Code: 4084 Please double check the cable and handset connection! Try it again! What else? |
03-12-2014, 03:19 | #10 (permalink) |
Freak Poster Join Date: Nov 2010 Location: romania, brasov
Member: 1439020 Status: Offline Thanks Meter: 16 | Make your handset power off, plug in the UART cable! Product: Vodafone555 Load DA file... Load AUTH file... Load flash image file... Start to connect the handset, keep pressing the power on key! Flash handset image failed! Error Code: 4084 Please double check the cable and handset connection! Try it again! are you using uart or micro usb cable? |
03-12-2014, 07:34 | #11 (permalink) | |
