08-30-2013, 14:43 | #17 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Somewhere in Spacetime Age: 48
Member: 168364 Status: Offline Thanks Meter: 174 | Voda 875 unlock I have PACK 6. Is there some tutorial for Vodafone 875 unlock ? As I see, the 1st step is to connect phone via USB without battery. The meta mode is with battery as 2nd step? I have XP SP3 so there have to be no problem with operating system and install drivers.I tried with a unit and it is always hanging and searching device as debug port (meta mode). I must say that tried only withot battery. Please help me if You can! Best Regards |
08-30-2013, 17:08 | #18 (permalink) |
Member: 168364 Status: Offline Thanks Meter: 174 | This is the error message: Searching phone; Phone detected (@oem98.inf,%vcom_preloader%;PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) ERROR: Debug port not found ! BE sure the drivers from support were installed; Time needed - 00:02:21 All drivers are installed! The phone details are: 355963054551445 SVN : 040HQG1 PROD. CODE : V875-2AVDHU1 Help! B R |
08-30-2013, 20:01 | #19 (permalink) |
Member: 168364 Status: Offline Thanks Meter: 174 | ...And the result: Vodafone 875 Smart Mini tutorial for all! 1. Unrar to ,,X" folder and install drivers from ALCATEL_MTK6573_Android_Unlock_Drivers.rar first with InstallDriver.exe 2. Connect phone to USB without battery 3. Select proper drivers from the same ,,X" directory if Windows ask You to do that. Preloader USB VCOM is now installed 4. Unrar to ,,X" folder Alcatel_OT-4010x_Android_Gadget_CDC_driver.rar 5. Run MTK reader 1.0.0.459. and select Alcatel MTK Android - Read Codes. (And not the perform direct unlock!) 5. Connect switched off phone to USB with battery 6. First the preloader port will detect. Wait until it disconnects 7. As the software starts searching for the debug port, the device manager asks for driver; Select Android_Gadget_CDC_driver.inf file for Android Gadget VCOM Driver from the famous ,,X" folder 8. Now wait until software finish, because the necessary drivers are all installed. (You shouldn't have to install MTK Android phone drivers for example, leave device manager hang.) 9. If something wrong or timed out until installing the drivers then repeat only the 5th step. It must work. Notification: I tested it on a phone after factory reset. It wasn't need to turn on USB debugging on its Linux Android system. It was turned off during the whole process. (Because device wasn't in modem or normal mode.) Worked fine under XP SP3 system and I could not install HOTFIX update. (It's only necessary on XP SP2) Not the easiest way to read security. Some skills are needed! ,,When you're talkin to yourself And nobody's home" (Guns n' Roses) B R |
The Following 2 Users Say Thank You to Demongsm For This Useful Post: |
09-03-2013, 17:16 | #21 (permalink) |
Insane Poster Join Date: Mar 2003 Location: Amsterdam
Member: 24510 Status: Offline Thanks Meter: 7 | I got the wrong code using the program. I included the log so you can see whats wrong. Also the Network ID is: V875-2BVDNL1 and the IMEI:355963-05-304020-0 I hope you can provide me with the working code. Thank you in advance Searching phone; Phone detected (PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM13); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6575 Sw version: MAUI.11AMD.W12.22.SP.V15.F5.P4 Hw Version: JRDSH75_CU_JB_HW Reading phone info; IMEI: 355963-05-304020-0 Reading simlock info; UNLOCK CODE: 04203328 Time needed - 00:01:01 |
09-04-2013, 12:09 | #22 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Quote:
Please try NCK: 06074414 Br | |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
09-06-2013, 15:44 | #23 (permalink) |
Freak Poster Join Date: Jan 2002 Location: Enschede, The Netherlands Age: 41
Member: 8594 Status: Offline Thanks Meter: 13 | I'm still having trouble unlocking this phone. The code read by the program is not working. The NCK you posted for me in other thread seemed to have unlocked something because the counter went from 4 back to 10, but it still needs an unlock code, maybe SPCK? I also asked for this in the other thread but got no reply. Please help. Searching phone; Phone detected (@oem180.inf,%mtk_preloader%;PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM111); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6575 Sw version: MAUI.11AMD.W12.22.SP.V15.F5.P4 Hw Version: JRDSH75_CU_JB_HW Reading phone info; IMEI: 355963-05-303675-2 Reading simlock info; UNLOCK CODE: 06948496 Time needed - 00:00:26 NCK: 03410184 |
09-06-2013, 23:52 | #24 (permalink) | |
Br | |
