10-13-2018, 14:14 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Bangladesh Age: 34
Member: 1217931 Status: Offline Sonork: 100.1604251 Thanks Meter: 267 | Vodafone VFD 620 Unlock possible? [YES=UNLOCKED] Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM11)) Preparing to start flash mode; Preparing to open COM11 ERROR: STATUS_BROM_CMD_FAIL ERROR: BOOT_PHONE; |
10-15-2018, 09:35 | #3 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Must connect with volume down and if you would bother to read then you could see unlock is not supported http://forum.gsmhosting.com/vbb/f272...-news-2486823/ Br |
The Following 2 Users Say Thank You to .:hack3r2k:. For This Useful Post: |
01-04-2019, 17:39 | #4 (permalink) |
Freak Poster Join Date: Jul 2006 Location: Ghana-Accra
Member: 311615 Status: Offline Sonork: 100.1591575 Thanks Meter: 72 | VFD 620 UNLOCKED WITH FGOLD BOX Using library Brom_DLL_v7.1813.3 Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) Phone detected (MediaTek USB Port (COM37)) Preparing to start meta mode; Requesting authorization; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6739,S01 Sw version: Hw Version: alps-mp-o1.mp1-V1.54_k39tv1.bsp_P21 Baseband Chip: MT6739 Sw version: MOLY.LR12A.R2.MP.V18.P22 Hw Version: TK_MD_L4_HW Reading phone info; IMEI 1: 353429-09-241674-6 IMEI 2: 000000-00-000000-0 Loading config; Done; Working; Unlocking; Phone unlocked; Remove battery and cable; Time needed - 00:01:52 Log file saved to: LOG_4_01_2019_16_36_19.txt |
The Following 5 Users Say Thank You to Abishalom For This Useful Post: |
08-31-2019, 15:33 | #8 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | done now Using library Brom_DLL_v7.1813.3 Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) Phone detected (MediaTek USB Port (COM50)) Preparing to start meta mode; Requesting authorization; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6739,S01 Sw version: Hw Version: alps-mp-o1.mp1-V1.54_k39tv1.bsp_P37 Baseband Chip: MT6739 Sw version: MOLY.LR12A.R2.MP.V18.P34 Hw Version: TK_MD_L4_HW Reading phone info; IMEI 1: 353429-09-265610-1 IMEI 2: 000000-00-000000-0 Loading config; Done; Working; Unlocking; Phone unlocked; Remove battery and cable; Time needed - 00:00:24 Log file saved to: LOG_31_08_2019_19_32_53.txt |
