Vodafone vfd620 unlock failed Using library Brom_DLL_v7.1813.3 Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) Phone detected (MediaTek USB Port (COM65)) Preparing to start meta mode; Requesting authorization; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6739,S01 Sw version: Hw Version: alps-mp-o1.mp1-V1.54_k39tv1.bsp_P54 Baseband Chip: MT6739 Sw version: MOLY.LR12A.R2.MP.V18.P41 Hw Version: TK_MD_L4_HW Reading phone info; IMEI 1: 353429-09-307695-2 IMEI 2: 000000-00-000000-0 Loading config; Done; Working; Unlocking; Phone unlock failed; Time needed - 00:00:31 Log file saved to: LOG_15_01_2020_15_44_35.txt |
You must select YES at new security ! It write clearly. If unlock fails on NO then you must repeat using YES Sent from my iPhone using Tapatalk Pro |
Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off with volume down pressed to the usb cable] Phone detected (MediaTek USB Port (COM65)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM65 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 4b5f811a84447d4c29896de770610a43 Requesting baudrate change; Done; DEVICE INFO: BB CHIP: MT6739 [CB00, 02, 6739, 00] HW_STORAGE_EMMC: 0x46000115 0x4D323645 0x31C70342 0xA7164ED0 [SIZE=0x3A4A00000] IMEI1 [OTP 0001]: 353429-09-307695-2 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: V620-2AVDGB2 USRDATA INFO: 0x96000000 SIZE: 0x30A2FBE00 Searching data; File not found; Phone unlocked; Remove battery and cable; Time needed - 00:00:01 Log file saved to: LOG_15_01_2020_16_04_57.txt |
Now unlocked ok:) Sent from my iPhone using Tapatalk Pro |
YES UNLOCKED working perfect |
