Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 01-15-2020, 11:16   #1 (permalink)
Member: 61595
Sonork: 100.1610188
Thanks Meter: 81
Vodafone vfd620 unlock failed
Using library Brom_DLL_v7.1813.3
Searching phone;
(insert the USB cable in the powered off phone
or
insert the USB cable in the powered off phone while keeping volume down pressed)
Phone detected (MediaTek USB Port (COM65))
Preparing to start meta mode;
Requesting authorization;
Searching for debug port; (be sure drivers from support were installed)
Meta mode entered;
Baseband Chip: MT6739,S01
Sw version:
Hw Version: alps-mp-o1.mp1-V1.54_k39tv1.bsp_P54
Sw version: MOLY.LR12A.R2.MP.V18.P41
Hw Version: TK_MD_L4_HW
Reading phone info;
IMEI 1: 353429-09-307695-2
IMEI 2: 000000-00-000000-0
Loading config;
Done;
Working;
Unlocking;
Phone unlock failed;
Time needed - 00:00:31
Log file saved to: LOG_15_01_2020_15_44_35.txt
Old 01-15-2020, 11:24   #2 (permalink)
.:hack3r2k:.'s Avatar
Member: 15022
Sonork: 100.53452
Thanks Meter: 55,913
You must select YES at new security ! It write clearly. If unlock fails on NO then you must repeat using YES
Sent from my iPhone using Tapatalk Pro
The Following User Says Thank You to .:hack3r2k:. For This Useful Post:
Old 01-15-2020, 11:36   #3 (permalink)
Member: 61595
Sonork: 100.1610188
Thanks Meter: 81
Searching phone in normal mode;
[connect the phone powered off with volume down pressed to the usb cable]
Phone detected (MediaTek USB Port (COM65)) (Driver version: 3.0.1504.0)
Preparing to start flash mode;
Preparing to open COM65
Connecting;
Downloading DA;
Initializing;
Rid: 4b5f811a84447d4c29896de770610a43
Requesting baudrate change;
Done;
DEVICE INFO:
BB CHIP: MT6739 [CB00, 02, 6739, 00]
HW_STORAGE_EMMC: 0x46000115 0x4D323645 0x31C70342 0xA7164ED0 [SIZE=0x3A4A00000]
IMEI1 [OTP 0001]: 353429-09-307695-2
IMEI2 [OTP 0001]: 000000-00-000000-0
PROVIDER: V620-2AVDGB2
USRDATA INFO: 0x96000000 SIZE: 0x30A2FBE00
Searching data;
File not found;
Phone unlocked; Remove battery and cable;
Time needed - 00:00:01
Log file saved to: LOG_15_01_2020_16_04_57.txt
Old 01-15-2020, 11:36   #4 (permalink)
Member: 15022
Sonork: 100.53452
Connecting;
Downloading DA;
Initializing;
Done;
DEVICE INFO:
Searching data;
File not found;
Now unlocked ok
Old 01-15-2020, 11:40   #5 (permalink)
Member: 61595
Sonork: 100.1610188
Thanks Meter: 81
YES UNLOCKED working perfect
Page generated in 0.25617 seconds with 7 queries
