01-16-2020, 00:59 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Cochabamba Age: 38
Member: 87396 Status: Offline Thanks Meter: 64 | VTR-L29 problem after downgrade for unlock and rebrand i have this problem i needed to unlock and rebrand 1 huawei p10 VTR-L09 on android 9.0 so i used testpoint and then flashed VTR-Downgrade-Board-A067-7.0.0_r1.fcff everuthing went fine with that firmware flashed phone turned on and worked with board firmware and did everything i needed now when i try to flash stock VTR-L29 firmware i always get error as you can see on the image i already tried 3 versions from support but still the same can anyone help me on this please thanks in advance |
01-16-2020, 08:34 | #2 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Quote:
You can only flash android 8 or higher after downgrade. Also be sure to set vendor and country values to match customization Br | |
02-19-2020, 06:45 | #3 (permalink) |
Freak Poster Join Date: Oct 2018 Location: cuba Age: 39
Member: 2870594 Status: Offline Sonork: yoandyveronika Thanks Meter: 28 | you are passing firmware vtr-l29a you tried with one that is vtr-l29b or pass board again and pass the firmware you want greetings |
02-20-2020, 19:00 | #4 (permalink) |
Member: 87396 Status: Offline Thanks Meter: 64 | Already solved, newer files are needed on support section, i had to search for the latest file in order to repair this unit everything fine after flashing with latest file |
