11-27-2007, 19:32 | #1 (permalink) |
No Life Poster Join Date: Feb 2001 Location: Fairyland
Member: 3383 Status: Offline Thanks Meter: 3 | w580 CID52 unlock problems FURIOUSTEAM pls advice i have this w580 for unlock which i tried to unlock by d/l the latest version semc sw from the support site here is the log of step 1 : Keep pressed "C" on phone and insert DCU-60 cable ! Phone detected ... Loading ... Loader version: 070129 0950 NGUCXC1250330_DB2020_PRODUCTIONIDLOADER_P3J [PHONE DETAILS] Baseband IC ID: 9900 Protocol ver.: 0301 OTP Cert. ID: 51 OTP Lock Stat.: 1 OTP Imei : 35923501XXXXXX PAF: 1 Color : RED Erom Cert. ID : 52 Flash Chip ID : 897E [SECURITY BYPASS START] [FLASH INIT STARTED] Loading ... Loader version: 061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 Loading ... Loader version: 061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 [FLASH INIT ENDED] Bypassing Security Step 1 ... [CS INIT STARTED] Loading ... Loader version: 070410 1557 HANCXC1250562_DB2020_CSLOADER_R3A009 Starting file system ... Please wait ! [CS INIT ENDED] Bypassing Security Step 2 ... Completed ... Restarting. Keep pressed "C" on phone and insert DCU-60 cable ! Phone detected ... Loading ... Loader version: 070129 0950 NGUCXC1250330_DB2020_PRODUCTIONIDLOADER_P3J [FLASH INIT STARTED] Loading ... Loader version: 061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 Loading ... Loader version: 061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 [FLASH INIT ENDED] Bypassing Security Step 3 ... Completed ... Restarting. [SECURITY BYPASS END] Operation Time - 00:07:18 STEP 2 : when i select unlock > do jobs : i get a window popup " NO FILE"s present in list " what file to select n where do i d/l it from ? pls help br |
The Following User Says Thank You to PTR999 For This Useful Post: |
11-27-2007, 22:33 | #2 (permalink) |
Freak Poster Join Date: Mar 2003
Member: 24754 Status: Offline Thanks Meter: 2 | Before you remove rsa you need to read info, then save fw details. Then load same fw file as phone, available at gsm-hacking, and then dojob unlock. But as most if not all people in the forum haven't unlocked a cid 52 i wouldn't waste my time on it and wait untill update becomes available to fix bugs. Also there are video tutorials on gsm-hacking's web site worth a look if you still stuck. JTG |
11-27-2007, 23:51 | #3 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
For cid 52 thres no need to check fw details as ful lflashing is performed so can use any fw As for VIDEO tutorials they are obsolete as they are for old versions. As for CId 52 some ppl managed do their job even with current version some bugs still are and im working to fix them thats true. Br | |
11-28-2007, 20:09 | #4 (permalink) |
Member: 3383 Status: Offline Thanks Meter: 3 | YEAH BUT THE PHONE I HAVE IS THE VERSION WHICH IS NOT THERE ON THE SUPPORT SITE STEP 1 WAS OK BUT FOR STEP 2 I NEED THE FLASH FILE OF THE SAME VERSION I SUPPOSE , THE ORIGINAL VERSION WAS Device IMEI: 35923501xxxxxxx, Device CID: 52 Model: W580i, Version: R6CA001 cxc1123364, Lang: ORANGE_GEN, Operator: CDA102774/18 R5A NOW WHEN I SELECT THE FLASH FILE ON THE SERVER THIS IS THE RESULT I GET : Keep pressed "C" on phone and insert DCU-60 cable ! Phone detected ... Loading ... Loader version: 070129 0950 NGUCXC1250330_DB2020_PRODUCTIONIDLOADER_P3J [PHONE DETAILS] Baseband IC ID: 9900 Protocol ver.: 0301 OTP Cert. ID: 51 OTP Lock Stat.: 1 OTP Imei : 35923501325762 PAF: 1 Color : RED Erom Cert. ID : 52 Flash Chip ID : 897E [UNLOCK START] Keep pressed "C" on phone and insert DCU-60 cable ! Phone detected ... & FREEZES ON THIS I M TRYING TO LOG INTO THE SUPPORT SITE BUT THE SUPPORT SITE IS DOWN THE CUSTOMER IS GOJNG TO KILL ME IF I DON;T GET THIS THING WORKING !!!!! PLS HELP A.S.A.P |
11-28-2007, 20:43 | #5 (permalink) |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | You have all the flash files available on www.gsm-hacking.eu/files . Latest version for se-fut is v1.0.0.1051. You dont need to select same version. Use any W580 flash file. Br |
11-28-2007, 20:51 | #6 (permalink) |
Member: 3383 Status: Offline Thanks Meter: 3 | oK NOW I WAS ABLE TO DOWNLOAD THE LATEST VERSION OF SE-FUT MODULW WITH WHICH I WAS ABLE TO FLASH THE PHONE FULLY WITH THE VERSION R6B001 DOWNLOADED FROM THE SITE BUT NOW CANNOT CUSTOMISE THE PHONE, SO THE PHONE HAS COME ALIVE BUT HAS CONFIGURAION ERROR PLS ADVICE ME WHERE TO DOWNLOAD THIS CUSTOMISATION FILE ? Keep pressed "C" on phone and insert DCU-60 cable ! Phone detected ... Loading ... Loader version: 070129 0950 NGUCXC1250330_DB2020_PRODUCTIONIDLOADER_P3J [PHONE DETAILS] Baseband IC ID: 9900 Protocol ver.: 0301 OTP Cert. ID: 51 OTP Lock Stat.: 1 OTP Imei : 35923501xxxxxxx PAF: 1 Color : RED Erom Cert. ID : 52 Flash Chip ID : 897E [FLASH INIT STARTED] Loading ... Loader version: 061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 Loading ... Loader version: 061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 [FLASH INIT ENDED] [CS INIT STARTED] Loading ... Loader version: 070410 1557 HANCXC1250562_DB2020_CSLOADER_R3A009 Starting file system ... Please wait ! [CS INIT ENDED] Customizing phone ... No customization files found ! Operation Time - 00:00:14 PLS ADVICE |
11-29-2007, 20:31 | #10 (permalink) |
Member: 3383 Status: Offline Thanks Meter: 3 | Hi , let me try to explain in details: redownloaded the SE-FUT_BETA_v1[1].0.0.1051 extracted n have a folder with 3 files in it : 1:tpa>preset>custom>.......n then is empty 2:usb_flash_driver>setup file is there 3:se_fut.exe pls double check n advice thnx |
11-29-2007, 20:54 | #11 (permalink) |
Member: 24754 Status: Offline Thanks Meter: 2 | Copy se-fut.exe into furious gold directory, and then run it, all will be ok. The directory is:- C:\Program Files\FuriouS-Gold on most pc's. It will ask you if you wish to replace the existing exe, select yes. JTG |
11-29-2007, 23:15 | #12 (permalink) |
Member: 3383 Status: Offline Thanks Meter: 3 | did it ..... copied all files to the d:\programfiles\furiousgold\ now also no errors occured but the phone after flashing starts but gives this error pn the screen " Configuration Error please contact network provider or service centre " anybody have experinces on this ????? any help on this will be highly appreciated thnx |
11-29-2007, 23:35 | #13 (permalink) | |
Br | |
W580 CID52 unlock with SLO LP (SEE Europe) | microera | Cruiser Suite | 1 | 12-29-2007 18:26 |
DB2020 CID52 unlocking problem | kgste | FuriousGold | 11 | 11-27-2007 18:26 |
w200i cid52 unlocking problem..please help... | :::..CyBoRg..::: | Universalbox | 4 | 09-20-2007 07:35 |
z310 cid52 unlock problem. | dway | Universalbox | 3 | 08-29-2007 17:35 |
