10-20-2017, 17:05 | #1 (permalink) |
No Life Poster Join Date: Jul 2010 Location: North Africa
Member: 1350724 Status: Offline Thanks Meter: 188 | wiko k-kool can not unlock i am trying to unlock this phone but unlock fail Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM168)) Preparing to start flash mode; Preparing to open COM168 Connecting; Downloading DA; Initializing; Rid: e025c7a52111971965c0a9ed78c21c79 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem19.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM239; DEVICE INFO: BB CHIP: MT6580_S00 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x484A0190 0x65314738 0xC7220705 0x6BC32284 [SIZE=0x1D2C00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 5:4470-85-000000-0 PROVIDER: N/A USRDATA INFO: 0x9B800000 SIZE: 0x135780000 Searching data; ERROR: UNKNOWN SECURITY ! ST33A004 File not found; ERROR: EXT4_SIMLOCK_REMOVE failed; Time needed - 00:01:03 Log file saved to: LOG_20_10_2017_17_58_05.txt |
10-22-2017, 08:59 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,552 | Select READ PARTITION -> and from the list select PROTECT1 Br;0 |
The Following 2 Users Say Thank You to .:hack3r2k:. For This Useful Post: |
05-23-2018, 08:22 | #3 (permalink) |
Insane Poster Join Date: Sep 2004 Location: KENYA
Member: 83870 Status: Offline Thanks Meter: 13 | wiko kool error while unlock with furiousgold,pls asist ing library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM26)) Preparing to start flash mode; Preparing to open COM26 Connecting; Downloading DA; Initializing; Rid: 87c55cd063970a95cf3c3063703e74be Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; ERROR: BOOT_PHONE; |
05-29-2018, 13:34 | #4 (permalink) | |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,552 | Quote:
Drivers not installed Br | |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
