10-02-2013, 13:17 | #1 (permalink) |
Freak Poster Join Date: Apr 2004 Age: 44
Member: 62154 Status: Offline Thanks Meter: 17 | Z990G can not unlock [SOLVED] How are you, i have Z990G can not unlock, this is the following log: Software engine version: 1.0.0.8750 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Mar 9 2012 22:11:00 RELEASE DATE : May 11 2011 02:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-60503001 IMEI : 86407201174218-0 BLUETOOTH ADDR : BB EB CF 2A 74 84 TAG_ID:P736TF05 UNSUPPORTED FIRMWARE VERSION FOR UNLOCK.IF THE CODE(S) DONT WORK SELECT DUMP ME FROM JOBS AND SEND THE RESULTED FILE TO SUPPORT. FOR ACER AND BOSTON MODELS FLASH DEVICE WITH FIRMWARE FROM SUPPORT CALCULATING; UNLOCK CODE [OLD]: 12267082 UNLOCK CODE [NEW]: 66081453 COUNTER CLEAR DONE; UNLOCKED ! Time needed - 00:00:02 Software engine version: 1.0.0.8750 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Mar 9 2012 22:11:00 RELEASE DATE : May 11 2011 02:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-60503001 IMEI : 86407201174218-0 BLUETOOTH ADDR : BB EB CF 2A 74 84 TAG_ID:P736TF05 STARTING DUMP ME; DUMP ME DONE ! Time needed - 06:05:39 Thank you for your help nang Last edited by .:hack3r2k:.; 10-03-2013 at 10:13. |
The Following User Says Thank You to nang For This Useful Post: |
10-03-2013, 10:16 | #3 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Quote:
http://www.mediafire.com/?k6gl7ou8ayjoiog | |
10-03-2013, 10:32 | #4 (permalink) |
Member: 62154 Status: Offline Thanks Meter: 17 | HELLO MASTER HOW ARE YOU, THANK YOU FOR YOUR HELP, PHONE UNLOCKED THIS IS THE FOLLOWING LOG: Software engine version: 1.0.0.8750 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Mar 9 2012 22:11:00 RELEASE DATE : May 11 2011 02:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-60503001 IMEI : 86407201174218-0 BLUETOOTH ADDR : BB EB CF 2A 74 84 TAG_ID:P736TF05 DONE; INIT NAND ROUTINES; NAND INIT MADE; READING SEC; CONTINUE DIRECT UNLOCKING; SIM_LOCK REMOVED ! RESET ! Time needed - 00:00:31 NANG |
