02-17-2020, 09:19 | #3 (permalink) |
No Life Poster Join Date: Sep 2011 Location: NOKIA
Member: 1663119 Status: Offline Sonork: iffi3 Thanks Meter: 213 | thx now its done Searching phone; For an successful connection do the following: 1. Power on the phone and power it off and leave the battery inside 2. Keep pressed firmly volume DOWN key 3. Insert the usb cable inside the phone while keeping pressed volume DOWN Phone detected (@oem135.inf,%usbcomm_dl%;SPRD U2S Diag) Preparing to sync; Port opened [COM15]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.1 Starting FDL2; FDL2 sent; Starting auth; HW IMEI : 000000-00-000000-0 Analysing data; Please WAIT ! OK; PHONE INFO: NONE BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 860250-04-005207-8 SW IMEI[1]: 867400-02-031662-0 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: ON Reading NV; NV saved to : NV_000000-00-000000-0_860250-04-005207-8_98550000_17_02_2020_10_16_01.spd Gathering security data; Security check result: 0 Connecting to server; Authorisation process started; Done; Requesting data from server ! Wait please ... Re-programming; Security programmed; Sync NV; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_17_02_2020_10_16_12.txt Time needed - 00:01:44 |
