02-03-2017, 16:30 | #1 (permalink) |
No Life Poster Join Date: Jul 2008 Location: UK
Member: 819396 Status: Offline Thanks Meter: 113 | ZTE Blade L3 possible to unlock? (solved) i have a ZTE Blade L3 to unlock. can i unlock with furious? i checked the latest otSmart and can only find ZTE Blade L3 lite on unlock list. any help would be great thanks |
02-05-2017, 14:51 | #3 (permalink) |
Member: 819396 Status: Offline Thanks Meter: 113 | Thanks for your help. unlocked successfully selecting ZTE Blade L3 Lite Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM43)) Preparing to start flash mode; Preparing to open COM43 Connecting; Downloading DA; Initializing; Rid: 687f1d2be16f0a6be61311e565b9ebe7 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem56.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM44; DEVICE INFO: BB CHIP: MT6582_S01 [CA01, 01, 6582, FF] HW_STORAGE_EMMC: 0x51000115 0x41535837 0xCEAF0142 0x0922ECC2 [SIZE=0x1D2880000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x44580000 SIZE: 0x8E300000 Searching data; File not found; ST33A004 Locked to [SIM1]: C1C-1C code_cat_n: 12345678 enabled: no tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: yes tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Code reading finished; Remove battery and cable; Time needed - 00:00:16 |
The Following User Says Thank You to heramiah For This Useful Post: |
