01-03-2020, 18:58 | #3 (permalink) | |
Freak Poster Join Date: Apr 2002 Location: Yugoslavia Age: 47
Member: 10594 Status: Offline Thanks Meter: 83 | Quote:
Code: Searching phone; For an successful connection do the following: 1. Power on the phone and power it off and leave the battery inside 2. Keep pressed firmly volume DOWN key 3. Insert the usb cable inside the phone while keeping pressed volume DOWN Phone detected (@oem54.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM242]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; ERROR: Sync failed; | |
01-03-2020, 20:09 | #4 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Post log from boot mode. Probably you have an different model which requires diff loaders Sent from my iPhone using Tapatalk Pro | |
01-04-2020, 07:49 | #5 (permalink) |
Member: 10594 Status: Offline Thanks Meter: 83 | Code: Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem54.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM242]; Entering diagnostic mode; Done; Chip type: 0000:0000 Platform Version: MOCORTM_18B_W19.10.2_ZLA_P8.01_Debug Project Version: sharkl3_pub BASE Version: FM_BASE_18B_W19.10.2_ZLA_P8.01 HW Version: sc9863A_modem 07-05-2019 16:55:51 Build number: GEN_UA_P963F01V1.0.0B09 PHONE INFO: BT ADDR: SW IMEI[0]: 868486-04-637504-6 SW IMEI[1]: 868486-04-638504-5 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: OFF Starting factory reset; Modem imei: 868486046375046 Working; Done ! Log file saved to: LOG_4_01_2020_07_41_32.txt Time needed - 00:00:11 |
01-04-2020, 12:08 | #6 (permalink) | |
Hi, Get from support SPD SERVICE TOOL - Update 1.0.0.3783 and select ZTE BLADE V10 VITA GEN and it should work Br | |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
01-04-2020, 12:20 | #7 (permalink) |
Member: 10594 Status: Offline Thanks Meter: 83 | Code: Searching phone; For an successful connection do the following: 1. Power on the phone and power it off and leave the battery inside 2. Keep pressed firmly volume DOWN key 3. Insert the usb cable inside the phone while keeping pressed volume DOWN Phone detected (@oem54.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM242]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.1 Starting FDL2; FDL2 sent; Starting auth; HW IMEI : 000000-00-000000-0 Analysing data; Please WAIT ! OK; PHONE INFO: NONE BT ADDR: NONE SW IMEI[0]: 868486-04-637504-6 SW IMEI[1]: 868486-04-638504-5 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: OFF Starting format; Formatted; Done; Remove battery and cable; Log file saved to: LOG_4_01_2020_12_17_18.txt Time needed - 00:01:06 Thank you, nice work |
The Following 2 Users Say Thank You to Scorpy For This Useful Post: |
