01-16-2014, 22:20 | #1 (permalink) |
Freak Poster Join Date: Jul 2010 Location: soudi arabia
Member: 1339076 Status: Offline Thanks Meter: 30 | zte Skinny V795 Mobile Phone unlock pack 6 but no signal pls help Sw version: MOLY.WR8.W1315.MD.WG.MP.V4.P11 Hw Version: ZTENJ72_WE_GB3_HSPA_HW Reading phone info; IMEI: 862025-02-026745-0 Reading simlock info; Locked to: C1C-1C code_cat_n: 12345678 enabled: no tries: 10 code_cat_ns: 56781234 enabled: no tries: 10 code_cat_sp: 11112222 enabled: no tries: 10 code_cat_c: 33334444 enabled: no tries: 10 code_cat_sim: 55556666 enabled: no tries: 10 code_cat_ns_sp: 77778888 enabled: no tries: 10 code_cat_sim_c: 99990000 enabled: no tries: 10 Time needed - 00:00:33 |
01-20-2014, 01:49 | #2 (permalink) |
Member: 1339076 Status: Offline Thanks Meter: 30 | Pls helppppppppppppppppppppppppppppppppppppppppppppppp pppppppppppppppppppppppppppppppppppppppppppppppppp pppppppppppppppppppppppppppppppppppppppppppppppppp pppppppppppppppppppppppppppp |
01-24-2014, 09:00 | #5 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | sorry i was power on and connect the phone.. now off the phone then connect to pc by usb cable Searching phone; Phone detected (@oem17.inf,%vcom_preloader%;PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM79); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6572, E01 Sw version: MOLY.WR8.W1315.MD.WG.MP.V4.P11 Hw Version: ZTENJ72_WE_GB3_HSPA_HW Reading phone info; IMEI: 862025-02-027461-3 Reading simlock info; Locked to: C1C-1C code_cat_n: 12345678 enabled: no tries: 10 code_cat_ns: 56781234 enabled: no tries: 10 code_cat_sp: 11112222 enabled: no tries: 10 code_cat_c: 33334444 enabled: no tries: 10 code_cat_sim: 55556666 enabled: no tries: 10 code_cat_ns_sp: 77778888 enabled: no tries: 10 code_cat_sim_c: 99990000 enabled: no tries: 10 Time needed - 00:02:13 but the phone has not network at all please i need help. thanks |
10-29-2014, 03:20 | #8 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | what means "file not found" Code: Using library Brom_DLL_v7.1413.5 Searching phone; Phone detected (@oem180.inf,%mtk_preloader%;PreLoader USB VCOM Port) Preparing to start flash mode; Preparing to open COM51 Connecting; Downloading DA; Initializing; Rid: 6417ff05479fdd960a05de42a5f3a071 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver\x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem180.inf,%mtk_sp_da%;DA USB VCOM Port) TRYING TO OPEN COM133; DEVICE INFO: BB CHIP: MT6572_S00 [CA01, 00, 6572, FF] HW_STORAGE_NAND: [Hynix] H9TA4GH2GDMCPR [AD:BC:90] [SIZE=0x20000000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x15740000 SIZE: 0x0A8C0000 Searching data; File not found; File not found; Time needed - 00:00:01 |
10-29-2014, 11:21 | #9 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Means that is an old version phone and you must use MTKreader to unlock it Br | |
04-06-2016, 09:28 | #10 (permalink) |
No Life Poster Join Date: May 2009 Location: Bangladesh/USA/UK Age: 39
Member: 1033714 Status: Offline Sonork: 1640811:mothertelecom Thanks Meter: 91 | vodafone smart speed 6 unlock done Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM Port (COM23)) Preparing to start flash mode; Preparing to open COM23 Connecting; Downloading DA; Initializing; Rid: 4e463f9f60c85cb39825de0b5ace0090 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (MediaTek DA USB VCOM Port) TRYING TO OPEN COM88; DEVICE INFO: BB CHIP: MT6735M_S00 [CA00, 00, 335, FF] HW_STORAGE_EMMC: 0x51000115 0x4D533237 0x14920042 0x73C280DC [SIZE=0x1D2880000] IMEI1 [OTP 0001]: 352185-07-322232-8 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: V795-2BVDGB2 USRDATA INFO: 0x99000000 SIZE: 0x39880000 Searching data; Locked to [SIM1]: 234-15 code_cat_n: 1374058711718093 enabled: yes tries: 10 code_cat_ns: 2906068389609400 enabled: no tries: 10 code_cat_sp: 0761269609123647 enabled: no tries: 10 code_cat_c: 3751997016375470 enabled: no tries: 10 code_cat_sim: 0390100604094669 enabled: no tries: 10 code_cat_ns_sp: 0390100604094669 enabled: no tries: 5 code_cat_sim_c: 0390100604094669 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:06 Log file saved to: LOG_6_04_2016_14_27_49.txt |
The Following User Says Thank You to mothertelecom For This Useful Post: |
