Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 11-17-2014, 08:46   #1 (permalink)
Member: 330445
Thanks Meter: 15
ZTE V811 unlock problem, please help [SOLVED=UNLOCKED]
MODEL : QCOM SERIES 42
COMPILED DATE : May 29 2014 18:38:00
RELEASE DATE : Apr 25 2014 04:00:00
FIRMWARE INFO : MPSS.TR.2.0.c10-00003-M8610BAAAANAZM-1
IMEI : 86520*********-9
BLUETOOTH ADDR : B3 B4 1D 62 12 0C
DONE;
WORKING;
ERROR: SIMLOCK READ !
Error ... !
Log file saved to: LOG_17_11_2014_12_47_06.txt
Time needed - 00:00:27
Old 11-17-2014, 10:57   #2 (permalink)
.:hack3r2k:.'s Avatar
Member: 15022
Sonork: 100.53452
Thanks Meter: 61,568
Theres no problem. This phone is simply not supported
Old 01-02-2015, 03:29   #3 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
hope will supported soon
Old 01-20-2015, 05:59   #4 (permalink)
Member: 1282563
Thanks Meter: 3
Please add ZTE V811 phone ASAP.
Old 10-14-2015, 03:54   #5 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
Root file from support then unlock with QCOM SMART TOOL MODULE Pack 5 ADB MODE must check
Connecting;
Check your phone and "Always allow from this computer" and select "OK".
Connected;
BRAND: ZTE
MODEL: ZTE V811
ANDROID: v4.4.2
CPU: QCOM
IMEI: 864509026181953
KERNEL: Linux version 3.4.0 (root@SCL_XA242_087) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Thu Aug 21 09:18:34 CST 2014
Cleaning;
Setting usb config;
Done;
Reconnecting;
Looking for the interface;
Port found [ZTE Handset Diagnostic Interface (COM115)]
Backing up sensitive data;
Done;
Backup saved to: 864509026181953.NV
Done;
Done;
Restarting the phone;
Setting usb config;
Done;
Reconnecting;
ERROR: Get interface failed !
Log file saved to: LOG_14_10_2015_14_55_28.txt
Time needed - 00:03:57
Connecting;
Connected;
BRAND: ZTE
MODEL: ZTE V811
ANDROID: v4.4.2
CPU: QCOM
IMEI: NA
Cleaning;
Setting usb config;
Done;
Reconnecting;
This phone has corrupted security. Select the backup to restore;
Restoring sensitive data;
Done;
RESTORED ! POWER OFF / ON THE PHONE MANUALLY TO COMPLETE !
Log file saved to: LOG_14_10_2015_14_59_21.txt
Time needed - 00:01:09
Connecting;
Connected;
BRAND: ZTE
MODEL: ZTE V811
ANDROID: v4.4.2
CPU: QCOM
Cleaning;
Setting usb config;
Done;
Reconnecting;
Done;
Done;
Done;
Setting usb config;
Done;
Reconnecting;
Done;
SIM_LOCK REMOVED ! POWER OFF / ON THE PHONE MANUALLY TO COMPLETE THE UNLOCK !
Log file saved to: LOG_14_10_2015_15_04_40.txt
Time needed - 00:04:09
The Following 2 Users Say Thank You to chris2007 For This Useful Post:
Old 10-16-2015, 11:22   #6 (permalink)
johnmadzeka1's Avatar
Member: 2377686
Sonork: 100.1668474
Thanks Meter: 315
Thumbs up It worked for me too
Connecting;
Connected;
BRAND: ZTE
MODEL: ZTE V811
ANDROID: v4.4.2
CPU: QCOM
Cleaning;
Setting usb config;
Done;
Reconnecting;
Done;
Done;
Done;
Setting usb config;
Done;
Reconnecting;
Connecting;
Connected;
BRAND: ZTE
MODEL: ZTE V811
ANDROID: v4.4.2
CPU: QCOM
IMEI: NA
Cleaning;
Setting usb config;
Done;
Reconnecting;
Done;
Connecting;
Connected;
BRAND: ZTE
MODEL: ZTE V811
ANDROID: v4.4.2
CPU: QCOM
Cleaning;
Setting usb config;
Done;
Reconnecting;
Done;
Done;
Done;
Setting usb config;
Done;
Reconnecting;
Done;
Good info bro keep it up
Connecting;
Connected;
BRAND: ZTE
MODEL: ZTE V811
ANDROID: v4.4.2
CPU: QCOM
IMEI: 866866025628691
KERNEL: Linux version 3.4.0 (root@SCL_XA240_218) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Sat Jan 17 16:05:37 CST 2015
Cleaning;
Setting usb config;
Done;
Reconnecting;
Port found [ZTE Handset Diagnostic Interface (COM83)]
Done;
Backup saved to: 866866025628691.NV
Done;
Done;
Setting usb config;
Done;
Reconnecting;
Done;
Log file saved to: LOG_16_10_2015_12_18_30.txt
Time needed - 00:09:08
Page generated in 0.18844 seconds with 8 queries
