11-17-2014, 08:46 | #1 (permalink) |
Freak Poster Join Date: Aug 2006
Member: 330445 Status: Offline Thanks Meter: 15 | ZTE V811 unlock problem, please help [SOLVED=UNLOCKED] COMPILED DATE : May 29 2014 18:38:00 RELEASE DATE : Apr 25 2014 04:00:00 FIRMWARE INFO : MPSS.TR.2.0.c10-00003-M8610BAAAANAZM-1 IMEI : 86520*********-9 BLUETOOTH ADDR : B3 B4 1D 62 12 0C DONE; WORKING; ERROR: SIMLOCK READ ! Error ... ! Log file saved to: LOG_17_11_2014_12_47_06.txt Time needed - 00:00:27 |
10-14-2015, 03:54 | #5 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Root file from support then unlock with QCOM SMART TOOL MODULE Pack 5 ADB MODE must check Code: Connecting; Check your phone and "Always allow from this computer" and select "OK". Connected; BRAND: ZTE MODEL: ZTE V811 ANDROID: v4.4.2 CPU: QCOM IMEI: 864509026181953 KERNEL: Linux version 3.4.0 (root@SCL_XA242_087) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Thu Aug 21 09:18:34 CST 2014 Cleaning; Setting usb config; Done; Reconnecting; Looking for the interface; Port found [ZTE Handset Diagnostic Interface (COM115)] Backing up sensitive data; Done; Backup saved to: 864509026181953.NV Done; Done; Restarting the phone; Setting usb config; Done; Reconnecting; Looking for the interface; ERROR: Get interface failed ! Log file saved to: LOG_14_10_2015_14_55_28.txt Time needed - 00:03:57 Connecting; Check your phone and "Always allow from this computer" and select "OK". Connected; BRAND: ZTE MODEL: ZTE V811 ANDROID: v4.4.2 CPU: QCOM IMEI: NA KERNEL: Linux version 3.4.0 (root@SCL_XA242_087) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Thu Aug 21 09:18:34 CST 2014 Cleaning; Setting usb config; Done; Reconnecting; Looking for the interface; Port found [ZTE Handset Diagnostic Interface (COM115)] This phone has corrupted security. Select the backup to restore; Restoring sensitive data; Done; RESTORED ! POWER OFF / ON THE PHONE MANUALLY TO COMPLETE ! Log file saved to: LOG_14_10_2015_14_59_21.txt Time needed - 00:01:09 Connecting; Check your phone and "Always allow from this computer" and select "OK". Connected; BRAND: ZTE MODEL: ZTE V811 ANDROID: v4.4.2 CPU: QCOM IMEI: 864509026181953 KERNEL: Linux version 3.4.0 (root@SCL_XA242_087) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Thu Aug 21 09:18:34 CST 2014 Cleaning; Setting usb config; Done; Reconnecting; Looking for the interface; Port found [ZTE Handset Diagnostic Interface (COM115)] Backing up sensitive data; Done; Backup saved to: 864509026181953.NV Done; Done; Restarting the phone; Setting usb config; Done; Reconnecting; Looking for the interface; Port found [ZTE Handset Diagnostic Interface (COM115)] Restoring sensitive data; Done; SIM_LOCK REMOVED ! POWER OFF / ON THE PHONE MANUALLY TO COMPLETE THE UNLOCK ! Log file saved to: LOG_14_10_2015_15_04_40.txt Time needed - 00:04:09 |
The Following 2 Users Say Thank You to chris2007 For This Useful Post: |
10-16-2015, 11:22 | #6 (permalink) | |
No Life Poster Join Date: Apr 2015 Location: Hatfield Harare Zimbabwe Age: 42
Member: 2377686 Status: Offline Sonork: 100.1668474 Thanks Meter: 315 | It worked for me too Quote:
Code: Connecting; Check your phone and "Always allow from this computer" and select "OK". Connected; BRAND: ZTE MODEL: ZTE V811 ANDROID: v4.4.2 CPU: QCOM IMEI: 866866025628691 KERNEL: Linux version 3.4.0 (root@SCL_XA240_218) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Sat Jan 17 16:05:37 CST 2015 Cleaning; Setting usb config; Done; Reconnecting; Looking for the interface; Port found [ZTE Handset Diagnostic Interface (COM83)] Backing up sensitive data; Done; Backup saved to: 866866025628691.NV Done; Done; Restarting the phone; Setting usb config; Done; Reconnecting; Looking for the interface; Port found [ZTE Handset Diagnostic Interface (COM83)] Restoring sensitive data; Done; SIM_LOCK REMOVED ! POWER OFF / ON THE PHONE MANUALLY TO COMPLETE THE UNLOCK ! Log file saved to: LOG_16_10_2015_12_18_30.txt Time needed - 00:09:08 | |
