01-21-2006, 08:11 | #1 (permalink) |
Freak Poster Join Date: Jun 2001 Location: Nairobi, Kenya
Member: 5093 Status: Offline Thanks Meter: 3 | 8180 Blinking After Flash Downgrade I wanted to unlock an 8180 V11f so I flashed the DRIVE_C with version 105 (which now seems to have been a mistake), but I then went ahead and flashed the files for V105, and the phone powered on but could not see the simcard. I then flashed V11F (four files) but now the phone is just blinking when I try to power on. I had made a full flash back-up before starting the whole procedure but it was saved in BIN format. Is there a way I can fix it back to work once again? How can I convert the saved full flash in a format that I can flash it back to the phone? The phone is still detected by the s/ware and doesn't need the test point. I will be very grateful if anyone can assist me in this repair. Cheersin advance. |
01-21-2006, 11:48 | #2 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Canada Age: 44
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | for Flashing 3g you ned to selec 4 files for unlocking use thgis files u8138patched_for_u8180 and Flash it all will be goood phone wilbe unlocked and work fine |
01-21-2006, 15:20 | #3 (permalink) |
Member: 5093 Status: Offline Thanks Meter: 3 | Thanks, but where do I get those files? I have revived the dead phone by using the *.bif file via test point. I then unlocked it by redbox and the phone can power on now but has no display. Can you kindly tell me how to go about repairing the phone now? I also need where I can get the flash files you have mentioned. Cheers. |
01-21-2006, 18:32 | #4 (permalink) | |
No Life Poster Join Date: Aug 2003 Location: at home
Member: 36951 Status: Offline Sonork: 100.63212 Thanks Meter: 6,247 | Quote:
take the flash patched from HERE. just flash the phone with all 4 files and the phone will be alive and unlocked. br | |
01-23-2006, 05:44 | #5 (permalink) |
Member: 5093 Status: Offline Thanks Meter: 3 | Hi AndreS? I have flashed the 4ne with the files you gave but the problem is still there. The screen just blinks white but stops there. Is there a way I can flash back teh original full flash that I read and saved before I started the whole process? I read it using Blazer but it is in *.BIN format. I will appreciate any help to get the phone alive once more. Thanks. |
01-23-2006, 11:07 | #6 (permalink) | |
flash it with 8138 patched flash from support, unlock, flash again with 8180 tached (with TP) and the phone must work. try and post results. br | |
01-23-2006, 11:23 | #7 (permalink) |
Member: 5093 Status: Offline Thanks Meter: 3 | Hi? I want to try that method you have posted then give an update... Here are the files I have. I still don't have access to the Blazer support, but i requested. I lost my user details. I have: drive_c_cid41_r.ssw drive_media_cid41_r.ssw FS_Rec_IT_cid41_r.ssw U8180_phone_wcdma_4mbram_41r.ssw I dont have the patched flash for 8138 so if you have them, kindly give me a link I download then flash the phone and then post results. Thanks. |
01-24-2006, 07:42 | #8 (permalink) |
Member: 5093 Status: Offline Thanks Meter: 3 | Problem Sorted, thanks to all those who helped me, mainly AndreS for helping me bring the phone back to life. I still had to unlock it after reviving it, but I used Vygis Crack and flashed it then did the factory reset, then unlocked via the usual code 00000000. Phone type : LG-U8180 IMEI : 355549-00-******-* Phone GDFS version : U8180_V10 Please power ON phone ------------------------------------------------ Loading flashloader ... OK ------------------------------------------------ Loading certificate loader ... OK ------------------------------------------------ Loading internal loader ... OK Flash ID : 890D Flash type : Intel - 32 Mb Second flash ID : 8910 Second flash type : Intel - 32 Mb Loading production loader ... OK ----------------------------------------------- Reading phone info ... OK ------------------------------------------------- Loading flash loader ... OK ------------------------------------------------- Writing flash from file : U8180 to U8138_V100_Russia_drive_c.crw Decrypting file ... OK Writing flash ... OK ------------------------------------------------- Writing flash from file : U8180 to U8138_V100_Russia_drive_media.crw Decrypting file ... OK Writing flash ... OK ------------------------------------------------- Writing flash from file : U8180 to U8138_V100_Russia_FS_Rec.crw Decrypting file ... OK Writing flash ... OK ------------------------------------------------- Writing flash from file : U8180 to U8138_V100_Russia_phone_wcdma.crw Decrypting file ... OK Writing flash ... OK ====== Process completed ====== Operation time - 57:34 The phone is now Alive and 100% unlocked... |
01-24-2006, 07:51 | #9 (permalink) | |
No Life Poster Join Date: Nov 2002 Age: 43
Member: 17689 Status: Offline Sonork: 100.72392 Thanks Meter: 737 | Quote:
wat about a blinking of 8330 even after flashing with the patched one from support? | |
01-24-2006, 09:06 | #10 (permalink) | |
br | |
7210c after flash the confeguration key is 000000 and after flashing downgrading imei | lilong_lee | Universalbox | 2 | 01-10-2010 11:13 |
Motorola A925 Blinks After Flashing With Flash Backup From Another A925 | iruocoop | Smart-Clip | 4 | 06-19-2006 06:02 |
u8120 after flashing downgrade firmware ver 101 , | digitalsatlink | HWK | 3 | 01-15-2006 17:07 |
8180 dead after flash | MarcoSCG | LG | 4 | 08-18-2005 09:00 |
6510 big problems after flashing /downgrade | G$M solution | Nokia Digital Core Technology 4 ( DCT-4 ) | 17 | 10-05-2002 07:04 |
