Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Blazer
Old 04-28-2006, 13:51   #1 (permalink)
toptro's Avatar
Member: 74438
Unhappy Help pls !
I use blazer box since more as 6 months no problem.....
yesterday, I try to use it and now the program 8.4 launch, present the picture blazer 8.4 on the screen and all diseapears !
I try on other computer and .... same way the prog launch and diseapear !
I try to use 8.4b program to try to fix the problem but this is not a valid win 32 aplication ...
what may I do ?????
pls
many thanks in advance !
Old 04-28-2006, 14:05   #2 (permalink)
Member: 123133
Sonork: 100.999
connect it properly
check urs lpt setting .try to change urs usb port
its not good.
Kuku
Old 05-01-2006, 13:20   #3 (permalink)
toptro's Avatar
Member: 74438
Thanks for reply !
Hi !
Many thanks for your reply but the problem is not solved now.
When I launch the program without box : Box not found
When I connect the box, the red led is blinking and ... occurs that nothing appears on the screen
I try all for the parralel port and the power supply too ... as a usb hub with ext power supply
the same port is used for other boxes and all is ok ..
May I remove D4 ?
I will try and tell you what happend !
Thanks
t610 pin configuration ..pls help pls zent_88 Sony Ericsson 0 08-13-2006 11:21
t610 pin configuration ..pls help pls..... zent_88 Sony Ericsson Hardware Repair Area 0 08-13-2006 11:16
how to convert 3220b to 3220a.......pls help......pls vasim22281 Nokia Hardware & Hardware-Repair Area 1 07-09-2006 03:08
Samsung D500 someone help pls pls pls lil_buffy Phone Unlocking Codes & Maps 0 07-03-2006 20:04
c139 flash dead phone help pls pls! david69 ODM (Original Design Manufacturing) 3 02-18-2006 14:55
Page generated in 0.23178 seconds with 11 queries
