Unlock Server
Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Blazer
Old 01-03-2006, 22:28   #1 (permalink)
Member: 215248
LG 1300i Help!!
What cable should i used to unlocked an LG 1300i ??
I try all the cables that i have avilable and it tells me an error it won't connect into the phone?
what should i do?
Old 01-04-2006, 03:48   #2 (permalink)
Member: 108655
Cable D! Same cable for pretty much all North American LGs!
Also, remember to connect the cable to the phone and try to Connect Phone without the PHONE BATTERY! Seems weird, yea, but the box will turn the phone on despite having no battery.
Old 01-04-2006, 19:40   #3 (permalink)
Member: 215248
when i click on the POWER ON PHONE it says "The Phone It's On" so it powers the phone on but then the phone turns off after a few seconds. so i click on the "connect phone" button and it says "Communication Error" then it says Disconected...
can you gusy help me out in here pleasee!!!!!
I am using the software version 8.1.
Old 01-04-2006, 21:51   #4 (permalink)
Member: 108655
Yea, sometimes I find the phone connectivity a little bit finicky.
You can try just pressing Connect Phone first, you will see the same thing as the phone powers on for a little bit, then shuts down again.
Also, you can try pressing Power On Phone, count 5-10 seconds, then press Connect Phone. This is what I had to do before v8.1. Since v8.1 however, just pressing Connect Phone works pretty good.
Finally, make sure you are using Cable D!
Old 01-04-2006, 23:54   #5 (permalink)
Member: 215248
I do click on connect phone and it says "the phone is on" and in the screen it reads "PHONE ON" then i press on "connect phone" but i get this error messege "communication Error". I have try everything and nothign works.
I am 100% using cable D to plug on the phone.
also do i leave the sim card on or no sim card at all.?
Old 01-05-2006, 22:30   #6 (permalink)
Member: 108655
I don't put in a sim card if I can directly unlock the phone, but it shouldn't matter.
Try just pressing Connect Phone, and let it do its stuff. After a few seconds, if you see "Connecting Phone Please Wait...." then you've gotten it to work. Otherwise, it should just say "Disconnected" on top and you need to try again.
Failing that, you might need to look at buying a new cable....
NEED TO UNLOCK LG 1300i ...FIDO shynepo3 Phone Unlocking Codes & Maps 1 01-04-2007 04:16
HELP! LG 1300i phone needs unlocking! cmorris LG 0 09-12-2006 05:42
LG 1300i - Fido Canada Veritable Blazer 24 02-22-2006 01:42
unlock LG 1300i ?? cooloxf FuriouS II 4 11-27-2005 14:02
LG 1300i amitks_in Redbox 2 09-01-2005 19:55
Page generated in 0.28963 seconds with 11 queries
