Go Back   GSM-Forum > Product Support Sections > No More Support/Temporarily Closed > Blazer
Old 01-13-2005, 21:50   #1 (permalink)
Member: 97360
New Blazer problem ...help
I need some comment from Lg blazer'er . I just got my LG blazer yesterday and have some bad experience with this product. I also got a 5metre serial printer extention cable as it was not incuded inside the package.
Setuping the equipment is pretty straight forward and i tried to test each LG cables (A -F ) and the box is able to detect the cable properly. When i tried to test it on my LG 8120 ver 100 on my personal desktop computer, it kept prompting "communications error".
When i tried on the another computer, it is able to connect to the phone but it is very stable. When i tried to press the connect button , the program will said that "connecting phone ..pls wait " ....then it will said "communications error" before the program actually connected to the phone.
In summary , the sequence is as follow
"connecting phone ..pls wait" ==> "Communications error x2 " ==> "connected"
The problem has not yet end . Even thou it is connected , the program does not show the model of the phone and the IMEI number. Check this jpg file Sometime it is able to show the model of the phone and the IMEI but somehow it did not show all the IMEI number. In my first attempt, i press the unlock button and it kill my LG 8120 phone instantly. The phone is totally dead and unable to boot up with the battery . Fortunately i manage to get a replacement set from my seller.
During my second attempt on my new replacement phone , I have to connect to the phone over 50 times before it FINALLY show the model and all the IMEI number. I manage to unlock the phone finally.
Do any one has this similar problem as what i have encounted. I need some help badly cos my blazer look pretty unstable.
I suspect that my serial cable is too long or the F cable is faulty. Any advise. I read a thread about communication error , do u think it is the cable faulty. ?
Also , if the LG 81xx phone is dead , do u think i can recover the phone back by flashing the phone with the flash cable.
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Share on FacebookTwitter
Old 01-14-2005, 00:16   #2 (permalink)
Member: 97360
just got my new 1.8 metre serial cable , tried it but sill the same problem .. help !!
Old 01-14-2005, 17:17   #3 (permalink)
evan_silbert's Avatar
Member: 21920
Are you connecting USB power to the dongle?
Old 01-14-2005, 18:58   #4 (permalink)
Member: 97360
i think the dongle is refering to the blazer box. Yeah , i using the USB cable which come with the package. The USB power drawn power from the desktop PC.
Old 01-14-2005, 19:28   #5 (permalink)
Member: 21920
Alright. Just checking. That can cause communication errors.
And yes, I mean the box. Older customers like me have a smaller dongle
Old 01-14-2005, 19:37   #6 (permalink)
Member: 97360
actually, i suspect it is the USB power/motherboard driver issue. When i tried it on my PC , it does not work at all and it always give me communication error.
But when i tried it on my friend's PC , it is aleast better but take me around 50 tries before it show the model and IMEI number.
Old 01-21-2005, 01:36   #7 (permalink)
Member: 20231
Lg8120
ok i have unlocked 2 x 8120 with blazer , i forget which version is it.
the thing is i have the problem u described using blazer v6 and v62a,
and strangly things work better with v59b , connect well , show some strange letter and unlock well!!
Old 01-21-2005, 03:53   #8 (permalink)
UnlockingExperts's Avatar
Member: 59731
Sonork: 100.999999
I have same problem, i have tried it on LG8120 i have changed the cables tried different boxes but have same problem, "communication error" it detects the phone but mission incomplete. if any one can help.
Old 01-21-2005, 06:13   #9 (permalink)
Member: 20231
v59b
@instaphone
don't know if this is going to help u but as i said before only v59b worked for me!!!
Old 01-21-2005, 07:57   #10 (permalink)
Member: 97360
http://forum.gsmhosting.com/vbb/show...2&postcount=32
check this thread...
i have solved my problem by using my friend's pc whose motherboard is using intel chipset.
manage to unlock U8120_v104 successfully.
Refbacks are Off
GSMCity - GSM Hosting - 1999-2010
Page generated in 0.07385 seconds with 8 queries
