Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Blazer
Old 09-09-2005, 01:01   #1 (permalink)
Member: 108655
Sim Lock Menu - LG C2000
Hi! Fido in Canada has had the LG 2000 for a couple weeks now. Blazer can detect the phone with Cable D, can detect the Unlocking Code, but cannot unlock the phone by itself.
I know that I can put in say a Rogers Wireless sim card and punch in the unlocking code when the phone asks for it, but it seems like that just makes the phone accept the Rogers card in addition to the Fido one it was originally locked to. If the customer goes to the US and puts in a T-Mobile sim card, the phone will ask for the same code once again.
So, I would like to get to the Settings -> Security -> Sim Lock menu and manually disable sim lock with that code. What do I punch in to unlock that menu? The service code I have is 2945#*70001#, that works for LG 1300i, but not this one >_<
If it means anything, when I read Flash1 and Flash2 with Blazer, Blazer saves them to the 70xx folder. Maybe that means they're in the same series....
Old 09-25-2005, 01:21   #2 (permalink)
Member: 81554
How do I completely unlock this phone???
Everytime I insert a new sim card it asks for SP Lock code..
thanks.
Old 09-25-2005, 01:43   #3 (permalink)
Member: 89673
im use vygis crack unlock good but use Vietnam .........can i help me change band ???
Old 09-25-2005, 20:54   #4 (permalink)
Member: 108655
If you can get to the Sim Lock menu, then you can put in the code that Blazer got from connecting to the phone there, to disable SP Lock completely. Of course, I don't know what the code is to get to that menu....
Right now, I'm just writing the unlocking code onto a stick-it note and giving that to the customer....
If you go to Settings you can change which band the phone runs on, either automatic 850MHz / 1900MHz or manual 1800MHz. If you need 900MHz, that's hardware and can't be had on this phone.
Old 09-26-2005, 00:29   #5 (permalink)
Member: 81554
Same. I have those Avery Labels that I write on and stick onto the back of the phone..
Old 10-06-2005, 16:04   #6 (permalink)
Member: 81554
bump. .
anyone have an aswer to this?
Old 10-06-2005, 16:12   #7 (permalink)
Member: 81554
ok. . i just tried this..
you need 3 different network simcards
after you've entered them 3 times, it won't ask you for a password anymore
Old 10-06-2005, 22:28   #8 (permalink)
Member: 108655
Really?
Sorry for the stupid question, but did you try with a FOURTH company's sim card? Once you have inputted the code for a Rogers sim, for example, the phone won't ask you for the code for any other Rogers sim. I guess that means the phone is unlocked for that network.
Crap, I only have Fido, Rogers and T-Mobile sims on hand.... I guess I need to drive down and pick up a Cingular pre-paid kit....
Old 10-07-2005, 02:40   #9 (permalink)
Member: 81554
i have like 10 different other network simcards from all the countries i've been to..
thailand, taiwan, australia, uk, canada rogers, fido, usa t-mobile, cingular etc..
after about the 3rd time i've entered the code, the 4th, 5th, 6th etc.. all the other cards do not require simlock pin anymore.. !!
let me try master reset..
Old 11-13-2005, 05:31   #10 (permalink)
selfbox's Avatar
Member: 198770
Thanks Meter: 17
In other forum say than use a vygis crack download from
http://www.movillab.com/downloads.ph...ownload_id=112
Old 11-13-2005, 05:35   #11 (permalink)
selfbox's Avatar
Member: 198770
Thanks Meter: 17
What model did you used to unlock the C2000.this model is not listed,and can it change imei?
Old 11-20-2005, 16:01   #12 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 497
C2000 cant be unlock by Vygis Cracked
only Original
Old 11-21-2005, 00:41   #13 (permalink)
Member: 63961
Thanks Meter: 11
Please update to include LG c2000
I have a cingular LG c2000 which I cannot unlock with Blazer Box. Just says Simlock Deactivated so no code to enter so phone can be unlock. Blazer Team, Appreciate if you can include this model on the next update. Hope you can get it out soon. thanks
Old 11-21-2005, 01:23   #14 (permalink)
elektroserwis's Avatar
Member: 87382
Sonork: 100.96303
Thanks Meter: 6
Vysis soft oryginal is the best, two sekend unlock
Old 11-21-2005, 01:36   #15 (permalink)
Member: 87382
Sonork: 100.96303
Thanks Meter: 6
Vygis ok is the best
W950i Depersonalize SIM Locks menu attemts reset alextom KULANKENDI Server 1 06-16-2007 05:30
Sim Lock Menu - LG C2000 Veritable LG 0 09-09-2005 00:54
lg b1200 sim lock code Siemens man LG 3 08-12-2003 23:52
LG B1200 ( SIM LOCK CODE) its NOT NCK UHK LG 8 06-20-2003 10:08
Page generated in 0.22549 seconds with 9 queries
